C2 - Grab bar insert 1964
Old Apr 12, 2006 | 06:21 PM
robmiester's Avatar
robmiester
Default C2 - Grab bar insert 1964
My grab bar is cracked so I ordered a new one from Zip. The old one has six screws and the new one has four (also different screw placement/holes). Which is the right one? The new one is not fitting as well.
Old Apr 12, 2006 | 06:43 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
If I'm remembering correctly, 63 and 64 use 4 screws, 65-67 use 6 screws. I believe they sent you the correct part. Chuck
Old Apr 12, 2006 | 06:47 PM
jprop's Avatar
jprop
My 64 uses 4 screws.
Old Apr 13, 2006 | 03:29 AM
waynec's Avatar
waynec
63 and EARLY 64 had 4 screws, later 64 through 67 had 6 screws... you likely have the wrong one.
Old Apr 13, 2006 | 02:44 PM
JohnZ's Avatar
JohnZ
'67 had no screws (no grab opening).
Old Apr 14, 2006 | 02:52 AM
waynec's Avatar
waynec
Picky, picky!
Old Apr 14, 2006 | 08:46 AM
67L36Driver's Avatar
67L36Driver
JohnZ: '67 had no screws (no grab opening).
I could use one for my terrorfied passengers.
To C2 - Grab bar insert 1964
