Been busy working on the 62. Have the engine, trans, rear and front crossmember out. Sent the front cross member, the rear, and some suspension pieces out to be powder coated. The engine bay and frame have been cleaned and sprayed. Not show quality, but a heck of a lot better. I lierally chipped/scraped a couple buckets full of grease and dirt off the frame and suspension. I got the family involved and let them get their hands dirty too.
When I removed this part, there was a rubber pad/bushing with it. It broke as I was removing it. Does anyone know the name of the bushing and where I can find one? Wes
The carb is a #1850 600 CFM Holley with a milled choke, secondary jet plate instead of a metering plate, and a quick change vacuum diaphram spring cover. The carb will be run on top of a #461 intake. I decided to go with the 461 intake over the 397 intake due to the larger plenum area.
The radiator is a 62 replacement radiator made by Griffin that I picked-up from Rick's radiator Service in Azusa (626) 967-7518. Rick is restoring a 1955 Vette.
That's it Wes. You've gone and broken the steering. Now you have to go to rack and pinion. Too bad.
Seaside, this was actually a bit of a sore subject while I was under the car for the better part of 3 weekends cleaning the frame and chipping off large chunks of grease from the front crossmember. Prior to sending any front end parts out to be powder coated and ordering any stock front end parts, I strongly suggested to the wife that she gets a rack and pinion kit from Jim Meyers or TCI. What we spent isn't a whole lot less than what a TCI kit would have cost, especially if you factor in the disc brake kit we swapped from the 59. Better not hear a friggin word about the steering effort or stock handling.
One of the goals of going through everything was to make the car easier for her to drive, so she would drive the car more often. This car was picked-up for her to drive. Although the price was right, I had no interest in either a 62 or an automatic. If she uses the steering effort as an excuse not to drive it more, that'll be reason enough for me to cut it up and start racing.
livin, if it looks like I won't have the car back together in time for CF Cruise In in May, I may go ahead and drop the frame down like yours. There's not much left attached to it.
Cruz 59, thanks for posting the diagram. I broke the rubber piece that was between the radiator support and "909K" when I was removing it. DZAuto suggested to me that I cut a piece of an old tire to fit, so that looks like what I going to do. My goal for this weekend is to get the rear end back in, the front cross member hung, and the brake lines run.
I jsut finished the frame resto on my '62 replaceing just about everything. THird arm got new bearing & seal, Rebuilt steering box (other stuff was o.k.) It now steers and wheel turns 100% better than before. Takes no effort now to drive and turn the steering wheel. You don't need to spend thousands more on a R&P system
That rectangular rubber (tire carcass-like) piece is part of the front body mount; isolates (kinda) the mounting pad on the 909K from the bottom of the steel rad support.
Wes,
It all looks great! The pictures are awesome, Now that is the way I like to see rooms furnished!
However if I ever suggested anything like:
I would be sleeping alone for a few days.
I got no complaints with the wife, other than she seemed to conveniently disappear when it was time to crawl under the car and start cleaning. My son on the other hand was as happy as a pig in mud.
John, thank you for the feedback. Could you please confirm the order of the pieces: From top to bottom, rradiator support, rubber pad, shim, the 909K part, then bracket with lock tabs. Does that sound correct to you? Thanks again, Wes
