Installed new camber bolds in the rear end as the old ones were rusted pretty bad. I failed to mark the old ones. Is adjusting the cam and camber easy?
Will I be ok just leaving them alone until I'm through with the restoration and then take it to an alignment shop since the front end will need to be aligned anyway?
Next question, when shopping for an alignment shop what are some questions I should ask before taking my car to them?
Rear alignment is difficult to get a shop to do at all, let alone correctly. Shops that said they had done the rears of c2-c3 cars before and would do it - no problem - left the alignment of my c2 screwed up. I ended up doing it at home with a level, chalk, string, and 4 plastic or metal plates.
The camber can easily be set to zero with any carpenter's level. Take (2) 1 foot squares of sheet plastic or metal (cheap aluminum flashing?) and smear grease between like a pj sandwich. Put a sandwich under each rear wheel and set the camber. Just push down on the back bumper every time you make a change and the wheels will resettle. When the level says the tire is vertical, the camber is zero. Alignment is a bit harder. If you want a diagram and instructions, email me. Note that the floor that the car is on has to be fairly level (from left to right) to get it right, but I'll bet if you ask any alignment shop when was the last time they leveled their equipment, you will get a blank stare.
Check with your local Corvette Club or NCRS Chapter and see what alignment shop they recommend. The front end is conventional, just like passenger cars, but the rear end is unique. Setting rear camber is simple (assuming you've installed the little caps on the inboard bushing ends before installing the cam bolts), but setting rear toe-in (which is the most critical adjustment on the car) is totally unique to C2/C3 Corvettes and MUST be done correctly.
Linoleum floor tiles work, too. Just make sure you use the 'smooth', not the 'chunky', axle grease....
It's amazing how many owners use this method rather than get stuck with poor alignment - and how many ways there are to get the rear wheels to settle into position without rolling the car back and forth until you need hospitalization.
