which optima battery
Old Apr 20, 2006 | 01:48 AM
NINETNINEVETT's Avatar
NINETNINEVETT
Default which optima battery
Which optima battery will work in a 64 with a 327. red or yellow and what model number. thanks
Old Apr 20, 2006 | 08:34 AM
Mikey65's Avatar
Mikey65
I have the red one in mine.. Yellow is marine I believe but can't remember. Don't know the model though sorry..
Old Apr 20, 2006 | 08:41 AM
64roadster's Avatar
64roadster
St. Jude Donor '07
I'm ready to install an Optima battery as well, does your original battery hold down hardware still fit?
Old Apr 20, 2006 | 09:24 AM
noelga's Avatar
noelga
Yellow top is deep cycle (racing).
Blue top is marine.
The red top is the one to use for the street
Old Apr 20, 2006 | 09:34 AM
TXSTICK's Avatar
TXSTICK
I have a red in my 66. I did not use the org hold down. I bought one that hooks on each side of the tray and one bar goes across the top.
Worked well.
Old Apr 20, 2006 | 10:23 AM
Kensmith's Avatar
Kensmith
I had the red top and switched to the yellow. The yellow holds a charge longer and has the same cranking amps as the red. Both are excellent.
Old Apr 20, 2006 | 10:38 AM
65nassau's Avatar
65nassau
I used the original hold down with no problem. It's a larger rectangle than the optima battery (mine is a red top) . Since the battery hold down is held by a rectangular frame on TOP of the battery, and the terminals are now on TOP instead of the side ....the '+' terminal is kinda CLOSE to grounding out on the hold down's recatangular frame.
I arranged mine so that the battery + terminal is pushed about 1" away from the hold down frame, so that it won't ground out, I have had no problems whatsoever.
It's really nice to paint and clean that battery tray and be DONE with no more acid leaks.
Old Apr 21, 2006 | 03:23 PM
LB66383's Avatar
LB66383
Those of you with an Optima battery and a small block....since the battery is smaller, can you get it in and out without having to unbolt and move the coolant reservoir?
Old Apr 21, 2006 | 04:08 PM
65nassau's Avatar
65nassau
I was able unbolt the tank (hoses connected) ....and pull the whole mess over towards the valve covers. I could them turn the battery, and lift the battery out.
I have a ZZ SBC 350 crate engine though ....possibly a slightly different profile.
I would not want to try and accidentally pull a hose off a tank or worse yet, crack a fitting going into the heater core. Unbolting the tank is certainly the lesser of those evils IMHO.
Old Apr 21, 2006 | 11:21 PM
bluestreak63's Avatar
bluestreak63
I have a 327. Optima Red Top.
Model No. Red 75/35
Part No. 27980
CA 910
CCA 720
And yes, the reservoir had to be moved. But you shouldn't have to remove any hoses.
Old Apr 22, 2006 | 08:25 AM
65 Hardnoks's Avatar
65 Hardnoks
Stereo = Yellowtop
Radio = Redtop
To which optima battery
