Loud Squeek
Old May 1, 2006 | 09:51 AM
ren's Avatar
ren
Default Loud Squeek
I've always had a intermittent loud squeek in the front end of my 63 roadster. It sounds like it's in the coil spring. In the past, I've sprayed some lubricant on the top and bottom of the spring and it stopped. Now lubricating doesn't work. Is there anything specific that I should try to tighten or should I plan on replacing the front coils?
Old May 1, 2006 | 09:01 PM
project63's Avatar
project63
Doubt if it's the spring. Grease the ball joints good and if it's still there, my money is on worn out rubber bushings on the control arms.
good luck,
tc
Old May 2, 2006 | 07:57 PM
ren's Avatar
ren
Thanks, I'll try greasing the ball joints. I'm pretty sure that the bushings are shot too. They might be original, I can actually spin two bushings around. I'd like to find someone local that's familiar with a 63 suspension. I don't want to do just the bushings if I need something else.
Old May 2, 2006 | 08:12 PM
stingrayl76's Avatar
stingrayl76
Try spraying the control arm bushings with WD40.
There is nothing special about a 63 front suspension as it was used on most cars in the sixties. Any good front end shop can replace the bushings.
Dave
Old May 2, 2006 | 08:56 PM
SPLITRAY's Avatar
SPLITRAY
Wow, original a-arm bushings!!! I gotta believe that's the squeek.
To Loud Squeek
