SB Engine pull....
Old May 9, 2006 | 07:59 PM
Talisman51's Avatar
Talisman51
Default SB Engine pull....
Well, I finally got around to my cylinder leakdown test and it looks like it's motor rebuild time! Several cylinders had 70%+ leakage rates. Seems the rings are gone.
Ok...seems there is at least three alternatives for us home garage types when yanking a motor.
1) The shop manual recommends leaving the trans and bellhousing in the car.
2) A national car rag suggested pulling the 4 sp trans first and then the motor.
3) Several forum members suggested pulling the motor from the side, with the 4sp attached and the aid of a tilter.
I was hoping to utilize my Kwiklift and avoid the perils of the jack stands (given my advanced age), but looks like the fender height with the car up on the Kwiklift will be problematic. getting the motor to clear the fender (...especially If I pull the engine and trans together).
Anyhow.... please weigh-in with some details on what procedure works best other than pulling the body (did that last time).
Thanks as always...
JimV
Old May 9, 2006 | 08:25 PM
rongold's Avatar
rongold
From: Putnam Valley, New York. Amateur Radio Operator K2NS
Default Engine Removal
When I removed the 327 and reinstalled a 427 in my 67, I removed the radiator & fan, unbolted the bell housing, supported the trans, lifted the engine just enough to unbolt the motor mounts, slid it forwards to get the trans input shaft out of the pilot bearing and through the pressure plate fingers, and then lifted it straight out.
Installing the 427 was easier than I thought it was going to be--I lowered the engine into the engine compartment, lined up the trans input shaft, and gave a big push, and to my amazement, the engine slid back and everything slid into place--a one in a million shot. Bolted the motor mounts onto the block, and secured everything.
That's the easiest way to do it--Leave the trans and bell housing in the car.
RON
Old May 9, 2006 | 08:36 PM
Johns_65Vette's Avatar
Johns_65Vette
First I did this
Then this
Didn't take long...maybe about 3 or 4 hours total.
Old May 9, 2006 | 08:41 PM
Grey Ghost's Avatar
Grey Ghost
I pulled the 327 in my 1966, with a regular ol' cherry picker. I left the transmission attached and did not use jack stands. Install was just reverse the procedure. I didn't use a tilter, had 1 other person to help guide it back in. May have been a bit easier with the tilter though.
Old May 9, 2006 | 08:44 PM
tuxnharley's Avatar
tuxnharley
Default ...one additional detail
I agree - had the sb out of my '67 the same way. I would STRONGLY recommend removing the distributer first so to avoid the possibility of hitting the firewall on the way in or out. Don't ask me how I know.................
Old May 9, 2006 | 10:41 PM
Talisman51's Avatar
Talisman51
Default with tranny....
Did you have to do this first while down under....
1) remove drive shaft
2) remove/disconnect trans mount bracket
3) remove/disconnect linkage
On the reinstall how did you deal with the trans linkage and trans mount bracket and drive shaft (especially if you didnt use jack stands...)
THANKS>>>>>
Old May 9, 2006 | 10:48 PM
Talisman51's Avatar
Talisman51
Originally Posted by Johns_65Vette
First I did this
Then this
Concrats on your purchase...You and I were both hunting over the winter and had a chance to exchange ideas at that time.... Looks like we both bought low...and are now busting knuckles to get em goin.
Did you pull the trans prior to the motor, or did you leave the trans and bellhousing installed?
Old May 9, 2006 | 11:48 PM
Johns_65Vette
I left it all together. Didn't even pull the distributor. I only unbolted the driveshaft from the slip yoke. I didn't remove it entirely. I left the slip yoke in the trans, to keep the fluid in. All I did was remove the shifter handle (hurst shifter).
I hooked the pull chain to the intake manifold bolt holes just behind the exhaust crossover. That seemed to be a perfect balance point.
Old May 10, 2006 | 02:16 AM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
I have done it both ways, several times each.
depends on whther you want to do some tranny work, or cleanup, or such also,and how many people you have to help you.
On a removal, you can pretty much do it all by yourself by separating the engine from the trans. A reinstall that way needs two to three people, unless you are real patient and want to get up and down off the floor a lot.
Pulling and reinstalling the assembly as a package, should use two people, but it does save a lot of swearing from trying to get the trans input shaft into the clutch splines during reinstall under the car.
Removal and reinstall as a package does increase the possiblity of body and other component damage on the car.
Doug
Old May 10, 2006 | 03:22 AM
OldDog58Vette's Avatar
OldDog58Vette
From: Bonner Springs Kansas... pay no attention to that man behind the curtain. Hay...I know that guy!
Been there done that. It was a good idea at the time.
Old May 10, 2006 | 07:22 AM
vettes1st's Avatar
vettes1st
St. Jude Donor '06
Just reinstalled a 327 in a 63 SWC. Put engine/trans in as a unit. Used a tilter from the front. Removed the tilter handle and used an impact to turn it. Left driveshaft in the car. Left shifter on trans, just put it in 4th gear. It's close but goes with no problem. Much easier with a helper on the bottom side.
Old May 10, 2006 | 11:03 AM
Talisman51's Avatar
Talisman51
Default got a plan....
Sounds like...
Remove radiator, shroud, distributor...
PULL...leave bellhousing and tranny IN until motor is out....and see if I can get a high-lift long-reach crane so I can keep the car up on the Kwiklift.
INSTALL...(jack stands) one piece using tilter with linkage (4th gear) and slip yoke installed...
I still wonder about linkage and trans mount bracket clearance issues however.
Thank you to all who shared their experiences...!
JimV
JimV
Old May 10, 2006 | 12:14 PM
Johns_65Vette
JimV
JimV
I supported the trans with a floor jack, and allowed the assembly to come forward a tad, and then let the trans drop to allow the shifter bracket to clear the floor opening. Like I said in the previous post, hooking the chain to the intake manifold bolt holes just behind the exhaust crossover, was perfect. I did not use an engine tilter.
Old May 10, 2006 | 01:03 PM
C2BOB's Avatar
C2BOB
Sounds like...
JimV
JimV
Pull the fan and pulley off the waterpump but don't remove the shroud or radiator. Isn't necessary. Getting the clutch hub to accept the transmission input shaft going back in is a little fiddly. Make sure the clutch is well aligned (I use an input shaft stolen from another gearbox). Be patient and remember that you may need to turn the crank a bit to get the splines to engage.
Old May 12, 2006 | 09:46 AM
56chevy's Avatar
56chevy
Default engine pull
talisman
back the car on the kwiklift. it makes the pull SOOOOO much easier.
You can lower and raise the rear of the lift, which is now the front of the car.
Try it
Old May 12, 2006 | 11:08 AM
Allcoupedup's Avatar
Allcoupedup
I just can't see it happening with the shroud still in place - unless a straight vertical hoist is used and the engine is pulled without transmission. I highly recommend pulling as as unit. Once you get everything disconnected or connected, you can remove/install the engine/transmission in under 10 minutes.
Jim - I did the removal with my 65 about 2' off the ground and it was too high and things were a little rough becuase I tried w/o removing the radiator. Bad idea - good thing I was getting a new one becuase i chewed it up pretty good.
The replacement was done with the front on jackstands - just enough for me to get underneath with a creeper to manipulate the tailshaft housing in place. With the tilter, the end of the transmission will slide in UNDER the transmission mount. No fear though, you can just switing it around into place. While you have the tranny out you can clean it up and give it a new seal.
Brian
Old May 12, 2006 | 01:33 PM
Grey Ghost's Avatar
Grey Ghost
I did mine much like Johns65vette. Removed shroud, radiatior, overflow tank. Left the dist. in. Removed shifter and had one person help guide it, while I worked the cherry picker. It was fairly easy...I left the slip in the trans. and the driveshaft in the car.
To SB Engine pull....
Old May 12, 2006 | 03:24 PM
TJefferson2020's Avatar
TJefferson2020
The issue with coming at it from the front is that the nose on these things is so long the cherry picker hits the front of the car - unless you have a very large cherry picker. I find that removing a front wheel and going in from the side is better.
Also, I would remove the radiator - it is too easy to smash and break off the overflow nipple on the top of the radiator and if you do you are screwed. Radiators go in and out easy and they cost $500 so why take the risk?
Also, you don't have to lift the front of the car very much just enough to get the right angle - a tilter is really helpful.
Good Luck!
Old May 12, 2006 | 03:35 PM
Johns_65Vette
I just have the basic Harbor Freight cherry picker, and it just clears the nose. The mast is adjustable, and I put it at the next to the furthest hole out.
Old May 12, 2006 | 04:26 PM
Talisman51's Avatar
Talisman51
Default nice thought...but....
Originally Posted by 56chevy
talisman
Try it
Rats...backwards sounds great. Right now I am ready to pull and cant see, without the aid of about 6 people, how I would spin the car around in my sloped driveway and then run it up a fairly steep Kwiklift. Also, logistics in a two car garage s@$%%k not to mention a fairly low overhead garage door.
I will try it "brokeback" style on the install!!!!!!
Thanks....
