Frame number decoding
Old May 20, 2006 | 03:02 AM
Mark Nevill's Avatar
Mark Nevill
Default Frame number decoding
My frame has the following letters and numbers stamped twice on the top of the left frame rail.
SI06246
Can anyone decode this for me?
Mark.
Old May 20, 2006 | 03:49 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
It's the partial VIN derivitive, the serial number of the car that the frame goes to.
S =St Louis
106246 = the 6246th Corvette built for ??? year. They started with 100001 as the first car.
You have nothing listed in your profile, and don't give the year of the car. Chuck
Old May 20, 2006 | 05:42 AM
Mark Nevill
Default Thanks
Thanks Chuck. Its a 62.
Cheers,
Mark.
Old May 20, 2006 | 06:04 AM
Chuck Gongloff
The VIN, vehicle identification number, or serial number for that 62 would be:
20867S106246
That number should be on the tag spot welded to the steering column.
If you have the original engine, you should see
2106246 stamped on the left side of the engine pad in front of the right side cylinder head.
Then you'll see something like F0101R? on the right side of the engine pad.
F is Flint Michigan, 01 is January, 01 is the first day, and the R? or S? would be the original horsepower and usage either
250, 300, 340, 360 HP RC, RD, RE, RF for manual trans, SC, SD for automatic trans. Chuck
Old May 21, 2006 | 03:32 AM
Mark Nevill
Default Thanks again
Chuck,
Once again thank you for your info.
Unfortunately I have none of those original parts. It will be what you could call a Vetterod.
Cheers,
Mark.
To Frame number decoding
