interior painting prep question
Old May 28, 2006 | 07:02 AM
wib1961's Avatar
wib1961
Default interior painting prep question
Hopefully soon I will be getting to the interior restoration on my '61. What would be the best proceedure for preping the fiberglass interior parts ( center console, gage cluster ,kick panels, etc. ) for the new paint. I will be using spray can to do the job as that is all I have access to and any experience with , but am hoping to get some much needed "prep experience" from you guys. Thanks in advance for any suggestions.
Old May 28, 2006 | 07:37 AM
DansYellow66's Avatar
DansYellow66
Are you using paint or interior plastic/vinyl dye - might make a slight difference? In any case I would clean them very good with strong soap and then wipe them down a couple times with something like DuPont Prep Sol - an oil and wax remover. If they are in good shape, don't need any repairs, and your looking for an OEM look, you can probably just scuff them lightly with 1000 grit sandpaper and spray them. I don't know about a 61 but I don't remember finding any evidence of primer on my 66 interior parts. It would probably be a good idea to spray a light coat of adhesion promoter first like Bulldog or SEM sells. If your going for a superior finish to OEM then using a high build, sandable primer first and block sanding with the 3M rubber backing pads would the first step. If you have some small nicks or scratchs the red plastic spot putty you can buy about anywhere will probably take care of it. It's usually lacquer based and has some inherent shrinkage so let it cure out good before sanding down and its probably best to primer over any of these areas, at least lightly with a regular non-sanding primer. Also pick up some tack cloths and use them before each coat you apply to keep dust nibs and stuff out of your finished paint.
Dan
Old May 28, 2006 | 08:58 AM
Grey Ghost's Avatar
Grey Ghost
I agree with Dan. You can find all this stuff, at your local autobody paint supply store. You can also substitute Windex for the prep sol. Wash everything down heavily with it 3-4 times. Tac rags are about 1.00 each at Wal-Mart. Just lightly run them over the surface before painting. Don't press down hard on them. The Bulldog stuff may only be sprayable from a gun ? Be sure to mask all the areas to prevent overspray.
Old May 28, 2006 | 02:52 PM
wib1961's Avatar
wib1961
Guys, Thanks a lot for the valuable info.You'al never let me down. I will follow the instructions to the "T". Thanks again Wib
To interior painting prep question
