67 reverse light ?
http://www.corvettecentral.com
end that attaches to the wire. I have every thing
else. It was this way when I bought the car. I
don't know why someone would cut them off
like that. But thanks for the info Mike.
Shemp
http://www.lectriclimited.com/mainpage.htm
I bought the wiring harness from them, works great. The end of the wire "screws" on to the back of the socket much like the light bulb. If the wire was cut, you can likely replace just the socket. The assembly is close to $200 but I believe it will not have what you need. After replacing the harness, one backup light did not work. Found the socket was not making a good connection to the assembly. I did a "bubba" fix for now, ran a wire from the socket to the lens screw. Works until I get the bigger fish fried, then I'll spend the money on the assembly.
