Rim size >=(
Old Jun 12, 2006 | 07:37 PM
Mikey65's Avatar
Mikey65
Default Rim size >=(
Well I been messing with rear suspension and measurements and a bit of test fitting and just for sh$9s and giggles I am going to see how close a 275 tire comes to fitting or not fitting on a 9" rim. Of course AR doesn't make anything wider than 8" for the TTII which works out perfect as always. I like Boyds and Billet, but don't like paying $550 per wheel, and neither does my wife.
So ideally I am looking for a 5.5" backspace on a 9" rim in a style similar to the TTII. Anyone have any pics of other wheels or ideas? Anyone make more custom sizes for less ludicrious prices?
Any why is 17x9 or 18x9 so uncommom??
Old Jun 13, 2006 | 12:17 AM
00fxd's Avatar
00fxd
I guess it would be safe to assume that you have offset trailing arms??
Old Jun 13, 2006 | 06:55 AM
Mikey65's Avatar
Mikey65
Yes
Old Jun 13, 2006 | 07:32 PM
LIL QIK's Avatar
LIL QIK
1st Gear
Can anyone tell me what the most BS you can run with the Offset Trailing Arms is? It would be greatly appreciated.
Old Jun 13, 2006 | 09:16 PM
tdelph's Avatar
tdelph
not really but I had 17x8's with 5.5" BS and had a tiny bit of room where it almost hit the tub in the rear of the car...I was only running tires that where in the 245 range...not 275's...I aint saying they wont fit on a car that has flares or larger rear fenders but not on anything stock.
Old Jun 13, 2006 | 09:39 PM
Sky65's Avatar
Sky65
St. Jude Donor '05, '09, '15
http://www.vintagewheelworks.com/pro...heels/v45/17x9
Old Jun 13, 2006 | 09:43 PM
Mikey65's Avatar
Mikey65
I was told that 9" rim with 6" backspacing will work for offset TA and fit fine..
I think I am going to just run 255/45/17 on an 17x8 TTII 8" to make this easier.
Old Jun 15, 2006 | 06:50 PM
macdarren's Avatar
macdarren
same here 255/45/17 on 17x8 TTII with 5.5 BS, at least that is the plan still waiting for AR to build them.
Old Jun 15, 2006 | 07:09 PM
Mikey65's Avatar
Mikey65
Did you measure your backspacing? What is your plan with the sway bar and rear spring? What # spring are you running?
Old Jun 15, 2006 | 08:29 PM
tdelph's Avatar
tdelph
I hope you are ok with the dish on the rear. I didnt like the smaller dish on the rear than the front. If you run 17x7's w/4" BS on the front and 17x8" 5.5" BS on the rear...your front dish will be larger than the rear dish. My wheels used to bother me everytime I looked at them. I am a very **** picky person so...if you are OK with that...then I am sure most people wont even notice...most.
To Rim size >=(
