What's the better spark plug? 67 SB
I have a completely stock 327/350. Which plug would run hotter.....
Delco R45 or 45S. Any problem with the extended tip getting spanked by the piston?
I'd recommend NGK B-4. These are non-resistor plugs in the same heat range & electrode depth as the obsolete AC-45. Both plugs you mention are of the resistor variety. Alternately, you can frequently find AC-45 at swaps or on eBay.
Vark
funny you should say that.
I've developed a miss that I suspect is a plug issue from a voltage drop because of the resistor in the R45 plugs I use and I'm going to be getting and trying the NGK B4 plugs on Monday because they are a non-resistor plug.
[QUOTE=vark_wso] Both plugs you mention are of the resistor variety. [QUOTE]
r45 is the resistor version.
45s is the extended tip which needs to be indexed to popup pistons.
I sold a half dozen sets of 45 plugs a year or two ago but I think I still have a set or two somewhere.
If you substitute r45 or any resistor plug for the nonresistor 45, I would not recommend using resistor (radio suppression) wires with an old original AC Delco coil, since the increased load could damage the coil.
Originally Posted by saopm
So what does the “S” designate in R-45S?
Charlie
Originally Posted by NedP1
As to which plug would run hotter I believe the 45 is heat range and therefore they would be the same on the two plugs - R45 and 45S
compare plugs that are 43, 44, 45 - all 14mm but different heat ranges.
As has been mentioned, the "S" indicates the extended tip.
