Spark Plug Looms
Old Jun 17, 2006 | 03:35 PM
kenmo's Avatar
kenmo
Default Spark Plug Looms
Can anyone recommend any good spark plug looms...??? OR tell me what you are using...
I'm using Morso units similar to these Ford units...
And although they are rated for 8mm wires they always seem to tear up my 8mm plug wires... I was cleaning the plug wires today and noticed a few very small cracks... These are new plug wires I purchased about 2 years ago...
Cheers
Kenmo
PS: I mistakenly posted this in the C3 forum as well...
Old Jun 19, 2006 | 02:44 PM
kenmo's Avatar
kenmo
I find these a little too snug for spark plug wires and I seem always seem to slightly crack my wires as I guide them through the loom...
What are others using for wire management...
Old Jun 19, 2006 | 03:11 PM
SIXt7's Avatar
SIXt7
Try using a set indexed for 8.5 or 9mm...that would provide a fit that is less snug. I use an 8mm set for 7mm wires and there is no issue with tearing, etc. Get an Accel catalogue at local parts store and check them out.
Old Jun 19, 2006 | 07:28 PM
kenmo's Avatar
kenmo
Thanks... I will..
Old Jun 19, 2006 | 07:33 PM
ghostrider20's Avatar
ghostrider20
Stock.
I can run 8 MM through the stock routing.
Now, if you don't have all the shielding, you could still utilize the brackets, which do a nice job.
Mark
Old Jun 19, 2006 | 07:59 PM
nassau66427's Avatar
nassau66427
Active Streak: 90 Days
From: going faster miles an hour...with the radio on in browns mills new jersey
These work for me:
http://www.billetspecialties.com/ite...id=144&pid=770
Old Jul 14, 2006 | 12:36 PM
kenmo's Avatar
kenmo
I'm at a loss as how the spark plug wires are routed or managed by this Billet device... Any images of the wires actually engaging this unit...???
Ken
Old Jul 14, 2006 | 12:54 PM
ghostrider20
I think if you look closely, there are 2 halves to each piece, that are held together with the alen head screws in the above picture.
When you split them, you just lay the wire in the appropriate channel.
Mark
Old Jul 14, 2006 | 01:11 PM
nassau66427
That's how they work.
Old Jul 14, 2006 | 02:59 PM
GCD1962's Avatar
GCD1962
Cheers
Kenmo
No problem using these, but the fit is tight and you need to use some silicone lube to roll them in place
Old Jul 14, 2006 | 06:47 PM
Dave64's Avatar
Dave64
2023 C2 of the Year Winner - Modified
2021 C8 of the Year Finalist - Unmodified
2019 C2 of Year Finalist (appearance mods)
St. Jude Donor '19-'20-'21
You can also look in Summit, they have a couple nice units.
Old Jul 14, 2006 | 07:25 PM
magicv8's Avatar
magicv8
large Morosos for fat blue Accel wires with shielding on custom aluminum brackets
To Spark Plug Looms
