Replacement wheels
Old Jun 19, 2006 | 12:56 AM
pjarrett's Avatar
pjarrett
Default Replacement wheels
I'd like to put some Chevy rally wheels on my 1961 Vette. I need to know the maximum width of wheel and tire combo I can use. The suspension is stock, it maintains the original height. I ran across some 15x7 wheels, can those work?
Paul
Parker, CO
Old Jun 19, 2006 | 01:04 AM
TEP061's Avatar
TEP061
Im not sure what works but post pics of it when your done. Thanks
Old Jun 19, 2006 | 07:31 AM
66since71's Avatar
66since71
I have seen 15x8s from the C-3s fit nicely on late C-1s!
Old Jun 19, 2006 | 11:16 AM
pjarrett's Avatar
pjarrett
Default Replacement Wheels
15x8 seem pretty wide. Is there any issue with those wheels and the stock riding height? I've located some 15x7's that are really nice. I'd like to find out from someone if they do work before I mount a tire and try it out.
Old Jun 19, 2006 | 02:38 PM
kenmo's Avatar
kenmo
I have 15x7 American Racing Torque Thrusts on my 1960... No problem at all... Backspacing I believe is slightly under 4 inches... Maybe 3 7/8...
Old Jun 19, 2006 | 10:16 PM
pjarrett's Avatar
pjarrett
What kind of tires are you using?
Old Jun 20, 2006 | 03:17 PM
JoesC5's Avatar
JoesC5
I have '67 rally wheels(15X6) on the rear of my 56 with 225/70's and no problems. I still run the 15X5's on the front with 205/75's.
Old Jun 21, 2006 | 08:04 AM
wmf62's Avatar
wmf62
St. Jude Donor '07
i have corvette rally 15x8's on my 62 and they work OK,,,, sorta.... (look awesome though)
i have 215 x 75 x 15s all the way around and the rear tire sidewall (not the tread) will hit the wheel well opening lip about halfway down the sidewall when the rearend goes down as with a bump in the road, hard cornering, etc...
i use airshocks on the rear to control that problem, but 15 x 7s might be a better choice
Bill
Old Jun 25, 2006 | 08:44 PM
SMSC1's Avatar
SMSC1
This evening I just test fit a rally wheel on my 59, and remembered why I did not mount a set years ago.
Did you guys machine the front hub to a smaller diameter? Rears fit OK, but front, at least on my 59, only allows the wheel to slide about 1/2 way onto the hub.
Old Jun 30, 2006 | 09:30 PM
SMSC1's Avatar
SMSC1
ttt for questions about rally wheels on C1s.
To Replacement wheels
