Headlight issues w/67
Old Jun 19, 2006 | 11:09 PM
1oldvetteguy's Avatar
1oldvetteguy
1st Gear
Default Headlight issues w/67
I have an issue with the headlights on my '67. When I raise and turn on the headlights, none of the beams turn on...but when I press the dimmer switch, all 4 (high and low) beams come on. It's all or nothing. My first suspicion was the dimmer switch, which checked out OK. Any other ideas??
Old Jun 19, 2006 | 11:29 PM
66BlkBB's Avatar
66BlkBB
St. Jude Donor '13-'14-'15-'16-'17
I don't want to be smart here but just how did you check the dimmer switch? If you get power to all four headlights when you switch to high beam then you are getting power to the switch at all times. The only place that you can possibly have a problem other than the switch would be if the low beam wire was broken in the harness and the low beam wire is making contact with the high beam wire in the harness. When you hit the high beams, it in turn makes contact with the low beam wire and all the lights come on. But that means two breaks which is unusual without both sets of lights failing. Other than that I can't see where else the problem could lie.
Old Jun 19, 2006 | 11:35 PM
stingrayl76's Avatar
stingrayl76
How about 2 burnt out low beams???
Old Jun 20, 2006 | 01:28 AM
willowdog's Avatar
willowdog
Is it possible that the car was worked on by billy bob and he did not hook the wiring up correcty or rewired the harness to fix another problem, like the high-beams not working?
Old Jun 20, 2006 | 08:24 AM
66BlkBB's Avatar
66BlkBB
Your answer is better than mine and a lot easier to check. I didn't even give the burnt out low beam a thought.
Old Jun 20, 2006 | 10:53 AM
JohnZ's Avatar
JohnZ
If the dimmer switch is OK, you should see power at the tan wire terminal on it when in low-beam, and power at the light green wire terminal on it when in high-beam. If that's OK, the problem is further forward, either in the outboard multiple connector on the engine compartment side of the fuse block tan wire terminals, or further forward where the forward lamp harness connects to the headlight harness forward of the radiator support.
To Headlight issues w/67
