66 Transistorized Ignition HELP Please
Old 06-21-2006, 06:37 PM
Paintbug
Paintbug's Avatar
Default 66 Transistorized Ignition HELP Please
Anybody have a BB with TI ignition? Trying to go back with TI ignition on the car. I have the wiring diagram that is on T.I. Specialty's web site. Must of it I understand but my problem is the pink wires. I put in a new dash and engine harness which has three pink wires. to that's together which would go to the positive side of the coil. I've got another single pink wire that come out of the harness just above the wiper motor and another pink wire that come threw the fire wall from the dash harness. Can anybody help me with where these wires hook up to or direct me to where I can get the info that I need?
Old 06-21-2006, 08:41 PM
AZDoug
AZDoug's Avatar
Received 1,478 Likes on 905 Posts
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
A lot of info can be gained with a volt meter.
Which wires are hot with the ignition on RUN? Which wires are hot with the ignition on START?. Check them and tag them for future reference. With that info and your wiring diagram, you should be able to figure it out
Doug
Quick Reply: 66 Transistorized Ignition HELP Please
