Compression Ratio Guestimate
The cranking compression is a nearly flat 180 psig all around. 175 psig if the lowest and 187 psig is the highest. Given that the spec in the Chassis Service Manual is 160 psig for an L36 must I assume that the C.R. is above 10.25 : 1?
How much does the inlet valve timing (closing point) have on the cranking compression? If the inlet valve closed earlier on the unknown cam than on the L36 cam wouldn't that increase the cranking compression by itself?
D&%#@ I can't find the folder I put all those box labels in back in '93.
Most heads will CC a good bit larger than what the books say too. After a few valve jobs and the fact that was a nominal number anyway changes things too. I had a set of BB closed chamebr heads that were supposed to be 100 cc. They were 115!! We had to angle cut and flat mill them to get them down to 95cc.
Yes, a different cam will drastically change cranking compression. If it has a tighter LSA, is a smaller lobe, is a very aggressive lobe or it is advanced a lot, they will all show higher cranking compression.
The good news is you have good compression for pump gas use. You should be able to run fine right there on good gas.
JIM
The other week when changing plugs I ran a compression check and much to my suprise it topped the stock figure by 20 psig. I was expecting about 150 psig. This leads me to believe the cam has an earlier inlet valve closing than your ordinary L36 cam. Must be advanced some.
yes, both decks ran uphill front to back !
that has since been corrected
