nonoperating odometer
Here is what happens ....
The speedo itself works off of magnatism from the first worm gear and is free floating.The first worm gear also drives the odometers(from a different section of the gear) that is usually the part that is worn out but the reason it gets worn is because the total and trip odometers are way too stiff and won't roll like they should.
Now everyone has it in their heads that they just need worm gears and get mad cause they can't find any but in truth they need all the gears and the odometers PLUS that #1 worm gear is magnetic and IS your calibration so if you replace it and don't have a way to recalibrate the unit ....you'll be SOL
Probably not the cable ...this is very common
Jason
VetteInstruments@aol.com
