Leaf Spring???
Old Jul 10, 2006 | 10:55 AM
66jack's Avatar
66jack
Default Leaf Spring???
I am doing a body off restro.
What i need to know is how can i compress the leaf spring to hook it up to the trailing arm without scratching the powder coat...???
what kind of tools can i use to do this ??
remember the frame is off of the ground>>
thanks in advance
jack
Old Jul 10, 2006 | 02:50 PM
Ron78Z&66Vette's Avatar
Ron78Z&66Vette
I used a floor jack and block of wood when I hooked up my composite spring. My spring is rated at 360lbs and the only "real" weight I had in back was my differential and a recycle bin with a set of iron heads, my old coil springs & brake rotors . Kind of trailer, but it worked.
Not sure how "safe" it would be, but if that didn't work for you, maybe an industrial/military tie-down/cargo strap looped around the rear cross member & end of the spring?
Old Jul 10, 2006 | 02:56 PM
64roadster's Avatar
64roadster
St. Jude Donor '07
I had a few BIG friends help install my spring on the chassis without the body in place.
Old Jul 10, 2006 | 03:01 PM
nassau66427's Avatar
nassau66427
Active Streak: 90 Days
From: going faster miles an hour...with the radio on in browns mills new jersey
I put a bottle jack on top of the frame with a piece of cardboard under the jack. Wrapped a cargo strap under the spring and over the top of the jacka couple of times. Then jacked it up to compress the spring.
To Leaf Spring???
