Brake Problems...
I went to flush/bleed the system today and ran into a problem. Because of the DOT 5 I had decided to not use the Motive pressure bleader I bought and instead had my son in the car. Per a post by Duke I started with the left front, shortest route, to get rid of the old fluid in the MC. I had turkey basted the MC out and filled it with new DOT 5 prior to doing this. After a few goes, the brake system refuses to pressure up. The reason I was doing the flush in the first place was my pressure differential light (brake light) was coming on.
Am I missing something or has my MC failed?
Thanks,
Bruce
p.s. I've read the archives three-times over.
However, since he has a brake light that indicates a problem in the first place, think the system needs to be fixed first. Why is the light coming on (indicates an imbalance in the system normally caused by a leak)?
Also, I have pressure bled DOT 5 with good results. Just have to use low pressure (10 psi or so) and therefore low flow rates.
Plasticman
Did you drain your system completely, or drain the MC dry at any time? I started my 69' with out bench bleeding and it 4-5 hours of pumping and still no fliud. So I bought a mighty-Vac, and it still took 2-3 hours.
I had the same problem about three years ago with bleeding Dot5. Believe it or not, pumping the pedal to bleed the brakes agitates the Dot5 enough to cause air bubbles in the system. I had to use the power bleeder to get a pedal. If you decide to use your power bleeder, use very low pressure as Plasticman suggests.
Dave
If you started at the front of the car to bleed and for no apparent reason the the fluid flow stopped, go to either rear and open a bleeder screw after you pump the pedal. The fluid should flow out the back. It may quit, if it does, go back to the front. While you're bleeding the brakes, look for calipers weeping, seeping or leaking. Check along the main front/rear brake for leaks. If you see nothing, your master cylinder is probably bypassing internally and needs rebuilt/replaced.
PROBLEM: After an hour or so on the road the peddle stroke gets dangerously long and spongy. Bleed brakes again and find no air in system...I'm going crazy.....HELP PLEASE
Thanks, hgvracer
Thanks, hgvracer
Thanks,
Bruce
Over time, as the car is driven, the MC piston travel settles in at a "sweet spot" where there is a maximum travel (+/-). Just beyond this spot, there will be a buildup of sludge (and rust if DOT3 is used). This forms a ridge in the MC. When you bleed the system, there is insufficient (or no) back-pressure to stop the piston/seal from going past the ridge. When this happens, old seals will fall apart at the edge and leak.
It's very common for MC's to fail during the bleeding process because of this.
Over the past 40 years of doing brake jobs, all I had to do was look inside master cylinders prior to honing & rebuilding them to see the how this all occurs. I also looked at the seals under a microscope to see just how freyed the cups were.
New and/or rebuilt MC's right off the shelf can have the same problem.... they rust internally while sitting on the shelf. When they are bled, the rust chews up the seals.
I disassemble all replacement MC's and inspect them internally prior to installation.
When I'm doing a brake job, I inform the owner that they may have to cough up the change for MC work... even if it's working okay when the job starts.
Also... brake hose ballooning is a possibility... replace them if they are old.
IF ANYONE THINKS THIS IS WRONG, PLEASE TELL ME SO.
This is the second new MC. The first was my original MC after being sent to Corvette Central for a $250.00 sleeve job.
I'm losing my mind and I'm going to quit Corvettes and go up in the mountains and raise goats.
Thanks, hgvracer
Larry
Thanks for your help
