Loose Electrical Fitting
Question: How do I permenatly attach this "bulk head electrical fitting" to the attaching clip on the firewall so it doen't keep coming loose? It seems to be attached by the top and bottom clip, but when slightly moved, it cuts all power. I would hate to be somewhere and have to deal with this inconveince all the time.
What about silicone to hold it in place?
Any ideas?
Tod
I had it disconnected for the first time last year to clean all the connections and fount it difficult to disengage the locking tabs. It was covered with some undercoating material. Went back together with an audible click(s).Its possible the undercoating glues the tabs in the locked position.
What shape is yours in? Possibly buggered by Bubba?
Mark
3 options...I just replaced the dash harness on my 1965 and the connections, although factory, seem to lock together better.
Bypass it like you said: http://forums.corvetteforum.com/show...head+connector
Clean the contacts, coat with anti-corrosion and give it a try. I wound up using long small bolts (1/4 x 20 ?) with nuts on the other side to keep the connections tight. I think on my '66 that was the problem vs. corrosion.
I like the idea of cutting the red wire and sending it through the fire wall. BUT, what do I attache the red wire to then? I looked under the dash, but not sure what to hook it to...can anyone attach some photos? There's like 5 million wires under there and complex wiring is not something I'm good at.
I really want to start doing more work on the car myself, but these jobs scare the hell out of me. If I could only see what to hook the red wire to, I would do it tonight!
Tod
My 66 had a severe case of this very problem. The red wire was the culprit. I had to tie a shoe lace to the harness and pul it tight in an upward direction to make contact. I replaced the engine harness with one from Lectric Limited. It's not hard to do and I have not had an issue since. If you try to clean it up and reinstall you might try some dilectric tune up grease to coat your connections. I use this stuff on my trailer connections and it works great.
Dennis
I completely cleaned both plugs with a small wire brush. The I used electrical contact cleaner on both plugs. Blew dry and inspected. Most (if not all) corroson was gone. Then I used Dialectric grease and reinstalled plug.
The Test:
Well it works A LOT better now, but I can still get the power to cut out if I really work at it by wiggling the plug. I think I'll be o.k. until this winter when I can attache the red wire directly through the fire wall and reconect on the inside.
Question:
Since I can't afford a new wiring harness now, should I remove the fuse block and look for the red wire on the inside? I can't seem to find the main power wire on the inside of the car.
Lastly:
I felt great by starting to do these small jobs myself. I felt very empowered and gain confidence each time I attempt something. Plus, thanks to the great help on this forum!
Tod
Zip tie the plugs to the fuse box and/or Use nuts and washers to help draw them tight.
I don't think the bypass wire would take long to do. You just need to see a wiring diagram or have someone step you through it.
So I decide to keep the ol' girl afterall (the 65'). Wife and I are on our way to work Saturday on the highway and car completely stops running...no electrical power. Pop the hood...jiggle plug, problem solved.
Tonight I decided to go for it. I was sick of having to pay someone to do my work. I removed the fuse block and found the "red" main power wire. I cut it, spliced a lead wire through the fire wall (where a rubber gromet was) and reconnected the red wire where I cut it from the firewall plug.
Had wife come out to garage with fire extinguisher as I reconnected battery. NO PROBLEMS! I started car, checked all lights, radio, antenna, ect... everything worked great! Best of all, no electrical fires
I then jiggled plug while watching dome light, again, NO PROBLEMS! Now I know it may be a "bubba" fix, but I can't afford a new wiring harness now. Thanks to all who gave me the courage and insight to tackle this job myself
It wasn't that hard and I figure I saved myself at least 2 hours labor at a garage. Plus I have the satisfaction of having done it myself.
Tod
