C-1 Speedometer needle removal
Old Jul 26, 2006 | 09:19 PM
Workin On 59's Avatar
Workin On 59
Default C-1 Speedometer needle removal
Hi. Great forum. Can anyone advise me on the best way to remove the speedometer needle on a c-1? I just picked up a well used speedo and need to install a new face on it. Thanks.
Old Jul 26, 2006 | 09:39 PM
vettes1st's Avatar
vettes1st
St. Jude Donor '06
Just use your finger tips and pull it off.
Old Jul 26, 2006 | 09:54 PM
JOliver's Avatar
JOliver
slightly twist it counter clock wise and pull back while doing so.
Jason
Old Jul 26, 2006 | 10:47 PM
vintagecorvette's Avatar
vintagecorvette
I usually hold onto the shaft with a very small pair or needlenose pliers and then wind the needle counter clockwise.
oWEN
Old Jul 26, 2006 | 10:48 PM
vintagecorvette
I usually hold onto the shaft with a very small pair or needlenose pliers and then wind the needle counter clockwise. I simply tried to pulled one and broke it off.....
By the way be careful. The shaft is easy to break....
oWEN
Old Jul 27, 2006 | 10:26 PM
Workin On 59
Thanks to all who responded. I think I'll take it apart far enough to put a touch of Liquid Wrench on it for a few days to soak, then try the careful twist and pull counterclockwise method while holding the shaft with a small needlenose pliers.
To C-1 Speedometer needle removal
