Driveshaft angle
1. The old angle before I removed the driveshaft? (If its correct)
2. Adjust to a close to zero?
3. What angle were they built with at the factory? (I cant find specs)
4. Trial and error? (Adjust as I go) AKA- vibe checks!
Thanks for any input in advance
Thanks for your input!
Plasticman
The closer to one degree the better but less than one can cause premature needle bearing failure because they will not rotate enough to stay loose.
Thanks for the reading surface info Plasticman
I don't understand about using the oil pan rails for leveling. You're not after leveling the engine, but matching the angles of the input vs output shafts. On an IRS, it is usually easier to alter the angle of the engine/trans than the angle of the differential (longer distance between mounting points). The exhaust hanger acts like a shim to raise the tail of the transmission. On side exhaust cars, instead of the hanger, a rectangular shim is used.
You're not after leveling the drive shaft, you don't care, (within reason) if the driveshaft sits at an angle as long as the input shaft of the differential is exactly parallel to the output shaft of the transmission. That parallel, especially in solid axle leaf spring suspensions, will be at an angle to the ground. This doesn't matter. Also, the differential and trans shafts do not need to sit in the same axis, only parallel.
One caviate to all of this, the yolks on the driveshafts need to be properly phased inline when the driveshaft is made. If they are out of phase, this will cause vibration.
A little education about U joints
Take a shaft with one U joint in the middle. Slowly rotate it with both ends exactly inline, or in the same axis. Both ends will rotate at exactly the same speed. If held constant, both ends will rotate constantly. Now if you continue to turn one end constantly, but you bend the driveshaft at the U joint to form an angle, the output shaft no longer rotates constantly. It instead speeds up and slows down depending on the position of the U joint at any given point in the rotation. The AVERAGE is still the same. The greaster you make the angle, the greater the accelleration/decelleration becomes. Now think about reversing which one you are rotating. If you instead drove the output shaft at the same accellerating/decellerating speed as it was driven before, the former input shaft would now be the output shaft, but it again would be rotating constantly, but you need to be accellerating/decellerating the input shaft. This is what the second U joint of the system accomplishes. It reverses the accelleration/decelleration of the intermediate shaft resulting in a constant velocity out. As you may have caught, both ends have to accelleraste/decellerate at the same rate but exactly opposite. This is where the phasing of the joints on the driveshaft come in. As long as they are exactly inline, and the input angle exactly matches the output angle, the accelleration/decelleration will be cancelled out. The two end shafts will be turning constantly but the middle shaft, the drive shaft as we call it, will be accellerating/decellerating.
Good luck with your install SSS
I thought Plasticman was pointing out the rails should be parallel to the output shaft.
I think if you minimize the PLRO you will be fine, but I guess the previous post is a concern.
http://www.4x4wire.com/tech/pinionangle/
http://www.iedls.com/ptsetup.html
Plasticman
Plasticman
I use a yolk slid in the output shaft and a magnetic angle finder. Works on both auto and manual trans. Then the yolk on the input to the differential. Same procedure front and back. No need to add or subtract 90 degrees. Match the angles and at least in the verticle plane, they're aligned.
I use a yoke slid in the output shaft and a magnetic angle finder. Works on both auto and manual trans. Then the yoke on the input to the differential. Same procedure front and back. No need to add or subtract 90 degrees. Match the angles and at least in the verticle plane, they're aligned.
Plasticman
You can take the top plate over the second shifter location off and grind the top edges off and put some allen headed cap bolts in place of the hex bolts and that will let you raise the trany a little higher.
Make sure you have the thin style front motor mounts to let the motor set as low as possible in front, decreasing your ujoint angle at the tailshaft of the trans.
Make sure you have the thinest possible front pinion cushion between the front pinion mount and the bottom of the frame to let the pinion set as high as possible to make the differential more parrallel with the transmission.
Hope some of this helps SSS
I remembered at Ford we had a magnetic V-block that attached to the starter motor housing for engine/trans output shaft angle, similar to Plasticman's method on the pain rails. I believe at least some of the Ford equipment was available in the Ford Rotunda tool catalog in the special service tool area.
