Securing Corvette in Trailer
Old Aug 10, 2006 | 08:28 AM
61 Silver's Avatar
61 Silver
Default Securing Corvette in Trailer
I have an enclosed trailer that I am currently using D-rings and ratchet straps to secure Corvettes. I would like a better system. The system must be capable of working with more than one car. What is the best system and what vendor is the best for purchasing this system?
Thanks Ray
Old Aug 10, 2006 | 10:10 AM
Don Keefhardt's Avatar
Don Keefhardt
Not trying to be argumentative, but what is the problem you perceive with ratchet straps ? Are you concerned that axle straps put excessive loads on bushings etc ? Just don't like lying on the floor hooking stuff up ?
All the 'tire basket' tie downs I've seen require specific placement of D-rings, which sorta negates their use for different cars.
Done probably 200K+ miles towing race cars around in the past two decades, and still prefer ratchet straps.
Old Aug 10, 2006 | 10:51 AM
Donny Brass's Avatar
Donny Brass
C2 of Year Finalist (track prepared) 2019
2017 C2 of the Year Finalist
http://forums.corvetteforum.com/show...+northern+tool
here you go
Old Aug 10, 2006 | 11:12 AM
61 Silver's Avatar
61 Silver
The system that I am using has two ratchet straps and two adjustable straps. It seems like there is always one loose adjustable strap that I can't get adjusted correctly. The 61 seems easier to strap down than the 63 because of the solid rear axle. I get nervous putting pressure on the rear shock mounts when ratching down the rear of the 63. I posted the question to get responses like yours and what is the method of choice.
Thanks Ray
Old Aug 10, 2006 | 11:29 AM
Don Keefhardt
By 'adjustable straps', do you mean something like :
http://www.racerwholesale.com/produc...ee4a04a9227a91
If so, you'll always have a loose one...just the nature of the beast. I use 4 ratchets, and axle straps as appropriate (most of the race fleet here has 'eyes' or rings that the ratchet snap hooks can catch).
Axle straps, etc:
http://www.racerwholesale.com/index....ee4a04a9227a91
I don't like tying to shock mounts, as shock mounts are designed to retain 'up and down' movement, but aren't really made for tying vehicles down. Don't tow the Corvette that much, but when I do I put a long axle strap around the rear of the trailing arm, in front of the spring fixture (mid-year), than grab that with a snap hook on the ratchet.
Old Aug 10, 2006 | 12:23 PM
kenEDMUNDS's Avatar
kenEDMUNDS
Why not do it like the factory did? J hooks in the frame front and rear and rachet it down. IT keeps the suspension from moving also.
Old Aug 10, 2006 | 09:18 PM
firstgear's Avatar
firstgear
2019 Corvette of the Year Winner
St. Jude Donor '15
here is the set up I would get.....wheel nets....
http://www.macscustomtiedowns.com/sc...?idCategory=24
Old Aug 10, 2006 | 09:21 PM
OldDog58Vette's Avatar
OldDog58Vette
From: Bonner Springs Kansas... pay no attention to that man behind the curtain. Hay...I know that guy!
You WANT the suspension to move!!
To Securing Corvette in Trailer
