Correct Bulbs for Clocks?
Old Aug 12, 2006 | 09:54 AM
MYBLUEHEAVEN's Avatar
MYBLUEHEAVEN
Default Correct Bulbs for Clocks?
First of all thanks to DZ and others that made the clock removal possible. Now I have three inop bulbs, all three appear to be different sizes. And how do you remove the bulb from the green hooded one off the 6 o'clock clip? It looks like the whole thing is stamped together as one piece.
Old Aug 12, 2006 | 11:08 AM
62Jeff's Avatar
62Jeff
Clock bulbs are 1816
The bulb socket is press-fit into the metal hooded thingy. Look closely near the wire-end of the assembly and you'll see a seam. Pull carefully to remove it. May need to use a little screwdriver at the seam to pry it apart to get it started.
