My 64 roadster is done in base-coat, clear coat. In a fit on madness i bought a orbital buffer. Using the most benign buffing media i find i can buff to a great shine very easily. My question is how much danger is there of going thru the clear. Could a new coat of clear be applied? I love this thing but I'm worried. It's from Qriout's garage.
Get the Porter-Cable 7336 Sander Polisher at Lowe's for $99.
Get the backing plate and polishing pad kit from Meguiar's for $37
Get some #83 Dual Action Polish from Meguiar's and some #81 Speed Glaze from Meguiar's
Use the Porter Cable on speed 5 (never use speed 6 with foam pads as you will rip them apart). Go slowly over the area you want to polish with the #81 (move up to #83 if the swirls don't come out).
You will have beautiful results and you will never burn through your paint using these recommendations.
short and sweet... i have bc/cc (PPG 2021 cc). i use a 6" orbital MVP polisher (WalMart, about $15) with a faux lambswool bonnet that can be held with one hand, and Meguiars # 26 yellow wax. no swirls, no risk of burn-through; great shine... takes about a half hour to wax the car. when you're finished, toss the bonnet in the washer to clean it up for next time.
as long as you're not 'heavy-handed' with your buffing, there is next to no danger of wearing through the cc. however, you have to be VERY careful on edges and corners (especially with a big wheel) as you can burn the paint.
cc can be topcoated again, but it is best to be done in complete panels. spotting it will eventually show up as a 'ring' at the edges that will take constant waxing to keep hidden.
Bill
