Broken Bolt Removal
My 1962 exhaust manifolds have several broken studs in the lower flanges. At Sears I found and purchased a set of hex nuts which have splines on the inside and, when driven over a stud, work great to remove them (they were rust-welded in).
The remaining broken studs are flush to the flange, having sheared when I removed the exhaust pipes. I haven't had a lot of luck with the process where you drill a hole, drive in screw extractors with the twists on the ends and remove. Does anyone know of a similar set of screw extractors to those with the splines? It has occurred to me that, by driving a splined extractor into the hole the stud receives even more pressure to resist extraction since what's left of the stud wants to expand outward against the sides of the hole. Any words of wisdom?
Thanks, Ken
punch the stud, and drill out the center, with a regular handed drill bit, keep going up insteps in diameter, with the regular drill bits, and when you get somewhat close to the i.d. of the threads, use the left handed drill bit on a slow speed, when going slow, the bit catches, and with the material removed, it almost always cleanly unscrews the left over stud threads without any damage to the original tapped hole threads.
Now if they are totally rusted together as one, they might not be saveable by anything but drilling out and the next size up tap.
I broke off a stud extractor inside the remnants of a bolt in the rearward oil pan bolt of a big block I was wrenching on when he showed me this trick. We punched the piece of extractor thru the bolt, , used a lefty, and it cleanly unscrewed the remnants, and out came the broken piece of screw extractor behind it.
It worked great and I think it was only about 20 bucks.
I then use a Dremel tool with a diamond tip (1-1/2" long, 1/8" diameter shank with industrial diamond grit up about 1/2" of the shank - but they come in several shapes). The diamond tip will cut just about anything, including broken off "Easy Outs", taps, drill bits, etc. Once you start cutting with the Dremel, you can see the very tip of the threads. Think of this as "playing" Dentist and removing a cavity, but you are on the good end of the drill/tool. With some skill, you can then just "pick out" the rusted in threads of the broken off bolt, and they will sprial on out. The old threads in the manifold are then almost good as new, after running a tap through them with a suitable lube.
Have found the diamond tipped tools at Sears, etc. Not cheap - last time I purchased one, it was about $10. Found a package of them (20 per) at a swap meet for $15 (a real deal - but hope I don't need to use one again, but I am prepared).
Plasticman
Bill
1. Drill the center of the bolt as large as you can.
2. Use a left-handed tap set to tap the new hole with as coarse a thread as possible.
3. Soak the bolt with PB Blaster...a lot. Soak it again. Next morning, soak it again. 40 years of rust does not let go in 30 seconds.
4a. If the bolt is "proud" of the hole that it is stuck in, then drive a lefty bolt with a hex head or allen head, heat the area, and go to town.
4b. If the bolt is recessed in the hole, use at least two washers as thrust bearings to prevent the lefty bolt head from sticking when you drive it in. Heat the area and go to town.
Good Luck!!
In an act of desperation, I went back to Sears during the noon hour and asked a salesperson for assistance (Usually akin to spitting in the wind). This time I was directed to no less than four places in the tool department, all of which had some kind of "easy out" (unbelievable!). I found they carry a set of "bolt extractors" that are tapered and four-sided instead of the usual "twist" type. I am heartened since this is more or less consistant with the spline concept of the outside extractors - the four sides provide four edges to cut into the sides of the hole I'll drill. I will post the results of the use of this product and may be back to following some of the excellent advice everyone provided.
Ken
Jim
ELECTRICAL DISCHARGE MILLING or ELECTRICAL DISCHARGE MACHINING
(essentially the same thing)
EDM is a yet another way of machining objects. Both conventional and wire EDM processes are available.
Basially cutting metal with an electrical spark (either via an electrode or a wire). Tooling dies (for stamping, molding, etc.) use the process considerably.
Plasticman
Think about this realistically. If the threads are so rusted or messed up you break a 3/8 inch bolt off (or whatever size), what makes you think a 1/4 inch or 5/16" Easy Out is NOT going to break under the same torque load?
Lesson 1. Smaller bolts break with less torque than bigger bolts. If the big bolt broke, the smaller Easy Out is going to, too.
Lesson 2. Easy Outs and other extractors are hardened. Your drill bits aren't. This means you snap an Easy Out off in that hole, you will be using a torch to get it out, unless you know a safe cracker.
Lesson 3. The machine shop will charge you more to remove the broken Easy Out and rusted bolt than the rusted bolt alone.
Goal in Life: Throw the Easy Outs as far as you can throw them into some field so you are never tempted to use them again.
An old trick to remove bolts is with an electric welder, if you don't have an Oxy-acet torch. Zap the bolt until it glows. The melting point of a steel bolt and the cast iron manifold or engine part it is stuck in are very different and you can do this if you are careful.
Don't do it over your head, or with gas leaking around you, though. Remove the manifold and put it in a vice.
Plasticman
With the intake manifold removed, I made a 1" thick guide block for the Helicoil tap drill, and for the tap itself. The block was long enough to be bolted to two adjacent holes . Drill, tap, insert and life is good again. Yes it's time consuming and you need a set of duplicating punches to make the block. But....it works !!!!
Hgvracer
Hgvracer
