Solid lifter valve adjusting
Old Aug 21, 2006 | 04:07 PM
klen's Avatar
klen
Default Solid lifter valve adjusting
I read a paper on here a while ago by SWC about a procedure for adjusting solid lifter valves cold. I can't find it on my computer, can someone direct me to it ???
Thanks KLEN
65 - 365 hp
Old Aug 21, 2006 | 04:17 PM
ctjackster's Avatar
ctjackster
I think BarryK has it up on his website, the paper was a joint project between Duke and John, I believe
Old Aug 21, 2006 | 04:24 PM
Subfixer's Avatar
Subfixer
POSSE ZR-1 Driver
Here is the document..... Although the valve lash settings have been refined:
30-30 cam = lash .024 Intake and exhaust
LT-1 cam = lash .016 intake , .024 exhaust
(I think I got it right)
"30-30" AND OTHER OEM SB SOLID LIFTER CAM VALVE ADJUSTMENT
By John Hinckley and Duke Williams
30-30
The traditional method of adjusting valves one or more cylinders at a time with each cylinder at TDC is fine for hydraulics and for most solid-lifter cams, but NOT for the factory "30-30" solid-lifter cam used in '64-'65 L-76 327/365 and L-84 375hp (F.I.) Corvette engines (and in '67-'69 Camaro 302/290 Z/28 engines); this cam has VERY long clearance ramps that are .020" high, and at TDC for any cylinder, both the intake and exhaust valve for that cylinder are still on their ramps, NOT on the cam's base circle, which is why the Service Manual for all cars so equipped says specifically to set them "hot and running".
There is, however, a better way to adjust the valves with a "30-30" - you can set them "cold and not running" by setting the intakes at 90 degrees ATDC and the exhausts at 90 degrees BTDC - so the lifters are on the base circle, not on the ramps. This has been confirmed with cam lift/crank-angle diagrams, and I've done mine this way - results in a nice mechanical "singing" sound, no "clacking", it runs better, sounds better, idle is more stable, and throttle response is improved. Many other Corvette “30-30” and Z/28 owners have followed this procedure as well since we developed it, and all of them have seen the same positive results.
Set them cold at .026"/.026". The actual measured (stamped rocker arm) ratio at the lash points is actually about 1.37:1 (not the design 1.5:1, which is a theoretical max lift measurement – actual measured max lift with factory stamped rocker arms is about 1.44:1), so the clearance ramp, which is exactly .020" high on the lobe, is all taken up at .0274" clearance; .030" clearance with the valve closed is too loose - the ramp ends/begins before the .030"clearance is taken up, resulting in the valve being lifted off and returned to the seat at greater than ramp velocity. This will contribute to valve seat recession, and can cause valve bounce at the seats at high revs - it will also be noisy.
You can adjust two valves at each 90-degree rotation point, starting at #1 TDC, turning the crank 90 degrees at a time seven times (measure and mark your balancer first at 90-degree intervals from TDC). Removing the plugs simplifies rotating the crank, but you were going to change them anyway, right? Proceed as follows:
TDC #1 - 8E, 2I
90 deg. - 4E, 1I
180 deg. - 3E, 8I
270 deg. - 6E, 4I
0 - 5E, 3I
90 deg. - 7E, 6I
180 deg. - 2E, 5I
270 deg. - 1E, 7I
Start at TDC #1, then rotate 90 degrees at a time, setting at .026" cold. If you like, you can then go back after you're done to each cylinder's TDC position and check clearance on that cylinder's two valves, and you'll find that they've closed up to .024", indicating that both valves are still on the ramps at TDC, as I pointed out in the beginning.
Trivia - the point of max inlet lift on the "30-30" cam is at 112 degrees, with a lobe separation angle of 114 degrees (angle between points of max lift, not the geometric center of the lobe - the lobes on the "30-30" cam are asymmetrical).
This progressive procedure will ensure that you are on the base circle on ANY OEM Chevrolet cam for adjustment, and the factory-recommended clearance on other OEM Chevrolet small-block solid-lifter cams should be factored as well by the 1.37:1-vs.-1.5:1 ratio difference at the lash point and rounded-down to the next-nearest thousandth or two to ensure that the valves are picked up and seated at ramp velocity.
"097" cam
What about the original “097” Duntov (used from late ’56 to ’63)? The “097” Duntov was designed for .012”/.018” clearance with 1.5:1 rocker arms, but in 1963 the intake clearance was revised to .008”, and this was also recommended in Corvette News back in the late 50’s for “weekend competition events”; the tighter intake clearance gave a bit more effective inlet duration. Factoring the original .012”/.018” by the 1.37/1.50 rocker ratio correction yields .01096”/.01644, call it .010”/.016” (hot), so if you’re already running the .008” intake clearance, it shouldn’t be tightened any further. We recommend a (cold) setting of .010” intake and .015” exhaust for 283’s, and .008” intake and .015” exhaust for 327’s. A complete crank angle/cam lift diagram in Corvette News, Vol.8, No.4, indicates that neither the exhaust nor the inlet is on the clearance ramp at TDC of the firing stroke, so you can use the indexing procedure outlined earlier, or it’s also OK to adjust both the inlet and exhaust at TDC #1 and TDC #6 as outlined in the 1963 Corvette Shop Manual with the “097” Duntov cam; it has much shorter ramps than the “30-30” or the LT-1.
LT-1 cam
What about the later early-70’s “LT-1” solid-lifter cam? In the case of the LT-1, it’s OK to adjust the intakes at TDC (its closing ramp ends about 10 degrees BTDC, so it’s off the ramp at TDC), but the exhaust is still on its ramp at TDC, so the exhausts should be set at 90 degrees BTDC using the indexing procedure. Both intake and exhaust recommended clearances should be factored down by the 1.37/1.50 rocker ratio correction here as well, from the factory spec of .024”/.030” (hot) to a (cold) setting of .021” for the intakes and .026” for the exhausts.
The difference between “hot” (engine idle speed) and cold clearance on a cast iron pushrod engine is negligible, so clearances can be set cold, which is much more convenient. The clearances noted are derived by “factoring” the OEM recommended clearances by the ratio 1.37/1.5 to compensate for the actual measured rocker arm ratio of 1.37 at the lash point. That number is then rounded down. The factory clearances are derived from multiplying the maximum height of the ramp above the base circle by 1.5. When running hard, such as at sustained WOT, the exhaust valve head heats up considerably. About 80% of exhaust valve cooling is through the seat, but the stem temperature will increase also, which causes the stem to grow and decrease running clearance. This is why exhaust ramps are typically higher than inlet ramps – to allow for more stem growth and still maintain some running clearance to ensure that the valves seat fully. Since the intake valve is cooled by the incoming fresh intake charge, its temperature and clearance will remain more consistent over the entire engine operating spectrum.
The rocker arm nut should be tightened until a light drag is felt on the feeler of the same thickness as the recommended clearance. Then the clearance can be verified by inserting a .001” thicker feeler; if it won’t go, the clearance is between the two gages, which is just right. Normal engine service will usually result in slight loosening of clearances over time, and Chevrolet service recommendations from the 60’s recommend a lash check every 12,000 miles as part of a normal tune-up.
8/22/03
Old Aug 21, 2006 | 07:33 PM
SWCDuke's Avatar
SWCDuke
That's the trouble with the internet. Old stuff never goes away.
The paper was revised December 2005.
Request anyone who has this posted remove it and and post the latest revision.
Duke
Old Aug 21, 2006 | 07:45 PM
BarryK's Avatar
BarryK
Jack, i used to have it up on my site but since Duke updated the settings I didn't have the new settings so I pulled it off my tech articles page about 6-7 months ago
Duke, are the revised settings that Paul listed at the top of his post correct? I can change it in my copy of the article and repost it up for others to benefit from.
Old Aug 21, 2006 | 10:15 PM
L79vette66's Avatar
L79vette66
What would be the cold setting for TRUE 1.5 roller rockers? .026 or .030
Old Aug 22, 2006 | 12:56 AM
SWCDuke's Avatar
SWCDuke
No such thing as a "true" 1.5 rocker. They may achieve this at peak lift, but they won't be constant through the complete cycle.
The OE SB rockers are about 1.37:1 at the lash point and about 1.44:1 at peak lift with about a 0.3" inch lobe.
Want to know what your super duper double gold plated triple cam roller whazzo aftermarket rockers are through the entire lift cycle - measure 'em!
The info you need to determine the best clearance is the lash point ratio.
Duke
Old Aug 22, 2006 | 07:24 AM
klen's Avatar
klen
Thanks for the info guys. I am going to give this a try in the next couple of days--- should be interesting. I have an old chevy block that i " practiced " on last night ... The process seems pretty straight forward. Anything I should be careful of ?????
Thanks KLEN
Old Aug 22, 2021 | 12:36 PM
351just's Avatar
351just
1st Gear
Duke, will the valve lash method above work for a 1970 350 LT1 Camaro with Stock Cam. Affter reading the notes, it appears the 8 exhaust with get set at 90 deg and 5 exhaust will get set at 90 deg. Also setting the clearances cold, what would you recommed. Everything I have seen posted range from 16/23 to 21/26. Thanks Tom
TDC 2I
90 deg 4E 8E 1I
180 deg 3E 8I
270 deg 6E 4I
O 3I
90 deg 5E 7E 6I
180 deg 2E 5 I
270 deg 1E 7I
Old Aug 22, 2021 | 01:04 PM
vettebuyer6369's Avatar
vettebuyer6369
TDC 2I
90 deg 4E 8E 1I
180 deg 3E 8I
270 deg 6E 4I
O 3I
90 deg 5E 7E 6I
180 deg 2E 5 I
270 deg 1E 7I
You are responding to a 15 year old post.
To Solid lifter valve adjusting
