Stem Seals
originally they were all built with only the o-ring you mention on all 16 valves.
someone has had your guides machined for the other seals and that's good.
with the guide seals you may not need the o-ring seals. but they are easy to install while you have it apart. you have to compress the spring down enough to get the o-ring on that lower groove. then carefully decompress the spring, making sure you don't tear the o-ring, and install the keepers.
do you also have the cup oil deflector at the top op the spring, directly under the retainer? a lot of times these are discarded. they are not really necessary when you have the guide stem seals below.
some new valves do not have the lower groove in them for the o-ring seal also.
