Well, I hooked my XM radio into the power supply for my lighter. Problem is I just cliped the wires and attached it to the power supply, one was a puch on and the ground was through a light that I just clipped off . Right away I started having problems with the main radio cutting out ( an Antique Automobile Radio conversion )and needing to be reset. well I was out driving tonight and relized I had lost all my dash lights. I guess the lights are in series eh. The weird part I can't figure is that when I turn the headlights on the radio works just fine and dosen't shut down anymore. Help
Greg
It's hard to tell what's going on without more information. Is this XM an in-dash type unit or a Roady 2 portable unit? You clipped the wire going to the cigarette lighter? What light did you clip off? Are you sure it was a ground wire? Bulbs normally have a hot lead going to the bulb and get their ground from the socket housing. Can you post more details?
the XM is a roady xt. yea the ground for the lighter was a pluged in bulb. I cliped the wire to the socket housing for the ground wire. It apperead to me that the lighter had a hot to it and grounded thru the bolb housing.
I would put the lighter wire back, believe it is always on unless you cut the grey wire which is for the light. The yellow wire on the radio is power. The radio connector also has a grey wire, believe that is tied to the cluster lights as all cluster lights are grey wires. Sounds like the radio is getting power from that. I would power both XM and radio with same power and ground source so they work only when key is on or in acc position.
There's no ground wire for the lighter - the lighter housing is grounded through its contact with the cluster, and the cluster is grounded through its 14-ga. black wire that plugs onto a male spade just above the tachometer. The other (gray) wire going to the lighter housing is for the lighter illumination lamp whose hood snaps into two slots in the housing.
If you clipped the bulb wire to the lighter and used it for a ground, you probably grounded the power line for all the instrument lights through the xm radio (and blew a fuse or burned the light switch dimmer). None of the cluster instrument lamps have grounds. Only indicator lamps and courtesy lamps do.
Heavy sigh, at 6"4'' 240 #s if there is one place I hate working it's under that dash. Oh well. so it goes. So what do ya think. keep the power from the lighter , return the bulb to it's originial place and ground the XM power to the same ground i use for the radio?
yes, yes, and yes ( or any cluster or dash Zbar screw will do for a ground). The Zbar (across the dash) is part of the body frame (birdcage) and it is grounded to the chassis frame by a strap behind the front of the LH aluminum rocker/cover.
PS I am also 6'4" and I have an A-C car with ductwork in the way. I feel your pain.
Why not just plug the roady power cord into the lighter socket? That's what it's designed for.
Did you cut that connector off the roady power cord and are connecting the cord directly to the lighter power wire? The roady takes only 6 volts, the connecter drops the voltage.
I didn't like all that stuff hanging around the console. they sell a kit for about $30 consisting of a connecter that allowes you to hook up power, the car antenna and the XM antenna in one physical connection. reception gets much better and you can stash the power connector away out of site.
