Hardtop alignment advice
Old Sep 11, 2006 | 07:41 AM
jrepoff's Avatar
jrepoff
Default Hardtop alignment advice
I am trying to help a friend and found that when we installed his hardtop the female locations on the panel are not lined up correctly. Is this a common issue ?
This may sound silly but they are off about 1/2 inch to one side and this causes the top not to seat properly. Would it be easy to plug the holes and move all 3 ot just let it go ?
Any advice would be appreciated.
Thanks, John
Old Sep 11, 2006 | 07:46 AM
wmf62's Avatar
wmf62
St. Jude Donor '07
wrong hardtop?
Old Sep 11, 2006 | 08:21 AM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
What year? Different years have different configurations.
Old Sep 11, 2006 | 09:43 AM
gonefishn's Avatar
gonefishn
St. Jude Donor '09
Few years ago I read in the Service Manual (don't recall the section) that the hardtop is to be placed on the car from which the locations for the rear panel side attachements are then determined. Maybe the rear panel top locations where done in the same way (don't have the manual so can't check).
Is this top original to the car?
John
Old Sep 11, 2006 | 09:44 AM
jrepoff's Avatar
jrepoff
It is a 1957 hardtop on a 1958 car. The top can be put on and attached but when latches are connected and the 3 bolts are put in there is a small gap on the drivers side due to the slight offset. I measured the distance from each side on the cover and there is a little over a 1 inch difference meaning that if both were moved 1/2 inch over then the gap would not be an issue because the rubber seal would sit correctly.
Is this something that should be corrected by plugging the holes and relocating the female sections on the cover?
Thanks for your advice.
John
Old Sep 11, 2006 | 09:46 AM
jrepoff's Avatar
jrepoff
John,
I think it is the original top but not 100% sure. When the top is on it looks okay from outside but I am being very picky and want to have it fit correctly if possible. I am sure you understand how it is when you work on one of these cars, you want it to be perfect if possible or why bother doing it...
Thanks, John
Old Sep 11, 2006 | 11:47 AM
wmf62's Avatar
wmf62
St. Jude Donor '07
gee John, if it's a 57 top on a 58; it's not the original top. it may have always fit like that...
Bill
Old Sep 11, 2006 | 12:11 PM
jrepoff's Avatar
jrepoff
Bill,
The date code is a 57 date code (A late 57 date code) that actually lines up with an early 58 corvette. Thsi si why I think it is original.
Thanks, John
Old Sep 11, 2006 | 12:12 PM
DZAUTO's Avatar
DZAUTO
First of all, can you post pictures of this gap difference that you are talking about?
Second, regarding the female latches, are you talking about the 3 threaded fittings on the soft top cover? If so, is that cover with the 3 fittings original to that car?
Next, the 56-60 hard tops have a guide pin on each side right next to the weatherstrip for the door window. This pins fit into a short piece of chrome trim on the body. Does the hardtop have the pins and are these little pieces of chrome trim on the car? ALLLLLLLLLLL 56-60 hardtops have the same attachment configuration. Only the headliner design and some minor exterior stainless trim are slightly different. Thus, THEORETICALLY, 56-60 hardtops are 100% interchangeable as far as attachment to the car is concerned.
The little chrome pieces on the body for the hardtop pins had just a hole in them for 56-early 57. Later in 57 production, the holes were changed to slots to allow for some variation in the fit of the hardtop. These slots continued through 60.
Hope this helps.
Old Sep 11, 2006 | 12:19 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
John
OK.... you say you can install all 3 hold-down bolts (61/62 only has 2 bolts). but, for what it's worth, if you are talking about there being a gap between the rubber seal at the bottom edge of the side windows/rear window 'glass' to the deck lid, from the outermost hold-down bolts around to the door opening; then my 62 hardtop has a gap there also.
otherwise i'm having a hard time picturing what you're describing.
Bill
Old Sep 11, 2006 | 12:55 PM
jrepoff's Avatar
jrepoff
Thank you all for the responses it has been helpful. I am sorry I did not take pictures to show and help me explain. I think I have a better understanding now and can help.
Best regards, John
Old Sep 12, 2006 | 06:39 AM
jrepoff's Avatar
jrepoff
Is there a place where I can possibly find a template of where the 3 holes for the hardtop should be located on the cover ?
I would guess that the factory most have had something they followed ?
Any assistance would be appreciated.
Thanks, John
Old Sep 12, 2006 | 07:11 AM
The Corvette Kid's Avatar
The Corvette Kid
I have a 1961 corvette and according to my assembly instruction manual the assembled hardtop placed on the car is the template for locating holes. I hopes this helps,Bob
Old Sep 12, 2006 | 08:05 AM
jrepoff's Avatar
jrepoff
Thanks Bob...
Old Sep 12, 2006 | 08:41 AM
vintagecorvette's Avatar
vintagecorvette
Are the hardtop receivers on the right side?
I believe that the little hole should be on the inside.
oWEN
Old Sep 12, 2006 | 09:31 AM
jrepoff's Avatar
jrepoff
oWen,
The top has never been tampered with and the receivers all look correct regarding thier location. They are all located on the inside.
Thanks, John
Old Sep 12, 2006 | 09:38 AM
DZAUTO's Avatar
DZAUTO
If I correctly understand the gap that you are describing, it sounds typical. My 56 has this gap also (assuming we're talking about the same thing).
To Hardtop alignment advice
Old Sep 12, 2006 | 10:09 AM
jrepoff's Avatar
jrepoff
DZAUTO,
We probably are talking about the same thing. Like I mentioned, the gap is not awful but it is a small gap that if the holes were located another 1/2 to 3/4 inch to the passenger side of the car the gap may not be present. You can see light under the drivers side where it bolts down and the gap is about 1/4 to 3/8...
Thanks, John
Old Sep 12, 2006 | 10:13 AM
DZAUTO's Avatar
DZAUTO
With these early cars, they were just like diapers on a baby------------------------NO SUCH THING AS A NO LEAK!
Old Sep 12, 2006 | 11:00 AM
vintagecorvette
My last 1957 was the same. It was a factory hardtop only car and the top fit was less than perfect.
post some photos so we get a better idea.
oWEN
