Floating tachometer
Old Sep 13, 2006 | 02:20 PM
troberts's Avatar
troberts
Cruising
Default Floating tachometer
The needle on my tach floats, or is springy, when I accelerate quickly. At idle, and while driving at constant speed, it functions properly. Does the cable simply need lubing, or is the problem in the distributor or gauge?,
Old Sep 13, 2006 | 04:26 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
first, try lubing the cable...
Old Sep 13, 2006 | 06:59 PM
2toys's Avatar
2toys
Most likely the movement assembly in the head itself. I tried lubing it and then replaced the cable and housing, had small enhancement. My speedo needle also flucuates, they both need a rebuild. It's on my to do list for someday.
Old Sep 13, 2006 | 07:12 PM
63C2splitter's Avatar
63C2splitter
CF Senile Member
St. Jude Donor '08
Did the same on my 63 - lube, then replaced cable. Ended up having the unit rebuilt - now it works perfect.
Dave
To Floating tachometer
