Does this engine pad look correct?
Old Sep 18, 2006 | 10:36 PM
mtmcorvette's Avatar
mtmcorvette
Default Does this engine pad look correct?
Does this engine pad look correct? The Vin number matches the trim tag. I don't see any broach marks, or any machine marks. It is a 65 Coupe with 350 h.p. I am going to have this car judged in the spring of 07. I have never tried to post a picture so if this does not work I may need help.
Here is the link
http://i106.photobucket.com/albums/m...te/sep1809.jpg
Old Sep 18, 2006 | 10:49 PM
Grey Ghost's Avatar
Grey Ghost
Might just be the picture. But, the "73" and the "09" look a little different. I'm no expert though. All I'm saying is they look different. See how broad some look and others look thin in width ?
Old Sep 18, 2006 | 11:16 PM
knight37128's Avatar
knight37128
No "broach" marks. Makes me think "restamp". Just the fact that they are on a straight line.
Just my .02
Old Sep 18, 2006 | 11:29 PM
67L36Driver's Avatar
67L36Driver
"Broach marks" have been obliterated by 40 years of rust. JM .02
Old Sep 18, 2006 | 11:37 PM
buns's Avatar
buns
Here is a pic from my '66 327/350 for comparison.
Old Sep 19, 2006 | 12:30 AM
archtech's Avatar
archtech
I think when they stamped them it was done on one dye...hammered all at once... the stamp looks like some charaters were stamped individually; some seem deeper than the others...
Old Sep 19, 2006 | 02:45 AM
Seaside63's Avatar
Seaside63
Looks good to me. They weren't meticulously perfect coming off the line.
I always say, If they're TOO perfect they're probably fake
Old Sep 19, 2006 | 12:45 PM
Denney's Avatar
Denney
The two stampings (assembly date versus serial number) were stamped at different times and wouldn't use the same fonts anyway. The assembly date was stamped (in this case at Flint) on the engine assembly line and the serial number was stamped at St. Louis before it went into the car. The stampers pulled the characters from bins and ganged them together in a fixture before the hammer came out (this was done similarly at both plants). Often times as the characters would wear/break/get lost they would be replaced and could have been different looking, just as long as the info got stamped. That is also why you will often see "I" instead of "1".
Old Sep 19, 2006 | 01:12 PM
Joel 67's Avatar
Joel 67
Pad surface looks good to me.
The stampings are a little inconsistant but not enough to be an issue to me.
Old Sep 19, 2006 | 02:07 PM
JohnZ's Avatar
JohnZ
Looks "typical" to me - many pads had hardly any broach marks to start with, and they'll disappear after 40 years of exposure.
Old Sep 19, 2006 | 08:10 PM
Corbrastang's Avatar
Corbrastang
Just my .02
Makes me think the block has just been sitting around for a while-you know time wears at things especially small lines such as broach marks. Numbers look fine to me. With all the variations who is to say what is right or wrong on this forum besides experts such as john z and duke. Not I.
Old Sep 19, 2006 | 08:13 PM
Corbrastang
What is that 375 on the pad?? haha
To Does this engine pad look correct?
