Need to get a little help here. I purchased a set of knockoff wheels for my 66 and I've got one small problem. The previous owner had damaged one of the rims (I'd like to replace it but can't identify the manufacturer) The wheel is marked "KMC" and has the following numbers on the backside... 306065, and what looks like a date code: 3 20 01 Can anyone helpl out with this? Thanks, Tony.
Need to get a little help here. I purchased a set of knockoff wheels for my 66 and I've got one small problem. The previous owner had damaged one of the rims (I'd like to replace it but can't identify the manufacturer) The wheel is marked "KMC" and has the following numbers on the backside... 306065, and what looks like a date code: 3 20 01 Can anyone help out with this? Thanks, Tony.
There are a lot of folks out there like these... http://fixrim.com/wheel.htm http://www.mobilewheelrepair.com/
that do wheel repair... have you checked this route?
... or these folks, who've been around a long time... Ye Olde Wheel Shop
7281 Washington Blvd.
Elkridge, MD 21227
(410) 796-8400, (800) 526-8260 ; $80 to straighten alloy rims..
& Tires
I have a set of KMC knock off wheels on my car and wanted a spare. I ordered a spare from Volunteer Vette for $299. When it came I was surprised to find I could not tell the difference between it and my KMC wheels. Their wheel was mfg by Corvette America.
If you insist on replacement rather then repair, I'm sure you would be happy with the wheel from VV.
Also if your looking for points on judging I think your KMC wheels would be incorrect and a deduct even if they were all matching and dated. Others can clarify this, I won't pretend to be an expert on this.
