4spd Removal
Unbolt the exhausts and disconnect the tach drive cable.
Remove 2 of 3 engine mount bolts and loosen the third (front-most bolt)
Using a U shaped wood support straddling the oil pan to support the engine at the starter and oil filter engine casting pads, lower the rear of the engine until you can easily unbolt the clutch housing.
Remove the clutch housing with (hanging on the input shaft) the trans.
Note that you take a chance on cracking the rubber in the engine mounts if you dont remove the bolts. (Ask me how I know)
I have removed the trans without the clutch housing, and without loosening the motor mounts. I found it takes me longer, and I swear instead of enjoying working on an old Corvette.
IMO mechanical jacks (sizzors or screw type) provide better (fine) control under the engine support while lowering the engine.
When these cars were new, and the bodies were stiff and the body mounts hadn't sagged, there was more room between the crossmember and floor to pull the trans back.
I have 2.5 inch exhausts routed through (see through) Borla turbo mufflers with 2.5 in outlets. I can still hear Wolfman Jack on the stereo at 85mph with the top down - of course my headrests have speakers.
I thought you might be interested in reading this web page:
http://forums.corvetteforum.com/show...ferrerid=17138
it's a different animal (smaller and faster
