Dash Clips
Old Oct 11, 2006 | 01:45 PM
ren's Avatar
ren
Default Dash Clips
Going to pull the dash on my 63 this winter. I'm just trying to plan ahead. Are the dash clips re-usable? If not, where can you buy them. I don't remember seeing any at the usual vendors sites. Also, I am going to install a new clock. The center piece in my dash, isn't leather . It appears to be just metal. Can I purchase just the center piece and will it look like leather? Thanks in advance for any replies.
Old Oct 11, 2006 | 01:52 PM
63Eroadster's Avatar
63Eroadster
3rd Gear
Just completed this process. I assume you are asking about the pash pad clips? Long Island Corvette has the clips as well as most of the major Corvette suppliers. I could have reused about 1/2 of the ones I removed. There are also 5 clips the hold your cluster in place. They more than likely can be reused. Tip... When putting your dash cluster back install bolds about 6" in length and with 2 nuts (one on the inside of the dash and one on the out side) use the bolts like studs. This will allow you to hold the cluster about 4-5"s form its home position and you can do your wiring without as much pain? Good luck
Old Oct 11, 2006 | 01:58 PM
JohnZ's Avatar
JohnZ
If the clips you're referring to are the ones that hold the eyebrow pads to the main dash panel, you can plan on breaking half of them; all the usual vendors have them. Your main dash panel should be vinyl-covered fiberglass, not steel, and it's all one piece from pillar-to-pillar and from the base of the windshield to the tunnel.
To Dash Clips
