Headlight motor
CF Senile Member
Headlight motor
This morning I was planning to drive my 63 to work, but when I tried to raise the headlights, the passenger side opened, but the drivers side didn't open at all. (I drove my truck to work instead) When I got home, I tried it again (temp had increased by 20 degrees), and it opened (very slowly). What do you guy think I should try first? I have read through all of the posts I could find by doing a search, but didn't find quite the same problem. Is there something that can be oiled without removing the motor, etc....?
Dave
Dave
If your motors haven't been serviced in a while, I'd go ahead and do it (you've probably got some really old grease in there). Barry has hosted an article on doing it. It's not that bad of a job.
http://69.253.166.197/page1/page65/f...%20Rebuild.pdf
CF Senile Member
Tossin,
Those are good instructions with great pictures. If I have to remove the motors I will, I was just hoping there was something easier to try first.
Thanks for providing the article.
Dave
Dave
I agree. When I got my 65 the headlights wouldn't open or close. After pulling the motors apart and replacing the old, stiff grease they work great. I suspect the contacts on your electrical bits are worn/dirty enough to not be able to overcome the torque required to work against old, stiff, cold grease.
Also, if you end up taking the motors out, please make sure you soak the bolts that hold the motors in for a while (in an anti-seize spray or something else to help loosen them up). Don't ask why I know this.
Received 1,859 Likes
Once you pull the motors, also make sure your buckets move freely over their entire range of motion; it's tough for the motors to overcome stiff pivot shaft bushings.
CF Senile Member
Thanks for the input, and the good instructions. I will try to save this for one of the winter projects - would like to get some more drive time in before bad weather hits.
Is there some recommended parts I should order in advance, or is it just a mater of cleaning and lubricating?
Thanks again
Dave
Thanks again
Dave
Originally Posted by 62Jeff
Hmmmm. My rebuild was a simple disassemble, clean, regrease, assemble affair.
Took several hours for the whole job
CF Senile Member
Thanks for all the good tips. I just need to dig in and do it. With the AC condenser and the Electric fans, the space is pretty tight. May have to take the fans out to get some room. Any other ideas? (remove grill, from below, etc...)
Dave
Dave
Dave
Dave
The headlights will also operate slowly if they are not getting full power, ie. your battery is low. Worth considering before you start tearing things apart, but if the car was running when you tried to move the lights, its likely the old grease and or worn cogs inside the motor.
If you want to use the lights before fixing them, have someone gently push them open while operating the motors.
Don
Don
Originally Posted by SVXr
Um...I get a "site not found" when I click on the link in post 2. Can anyone direct me to the site?
