Does this make sense?
"All cast numbers are unaltered original and a perfect match to the car. The pad was resurfaced, broached and stamped with the correct numbers."
What does that mean?
And what are factory broach marks anyway?
Thanks for helping reduce my ignorance.
Smaller machine shops do not have such a machine. They can do the same thing. But, it leaves it without those marks. Some people look for the marks as another indication of an original engine. Rebuilding an engine, it is fairly common practice to deck the block. To provide a perfectly flat mating surface for the cyl. head.
Now....it sounds a little weird (to me) for someone to go to the trouble to try and replicate broach marks. But, the seller was upfront about the effort to put them back.
Instead of "matching numbers" and "correct to the car" stuff. Ask if, the engine is the one that was in it. When it left the factory.
Close; don't take this the wrong way Grey Ghost (Jerry).
"Broach marks" are left by the machine that cut the raw casting. It was a big machine (I heard it described as the size of a locomotive) that cut the block in one stroke. It made the block "true". If the block hasn't been decked it will have straight line left from this procedure. Machine shops can not afford a machine like this. They use a smaller machine to deck the block it uses a rotary cutting tool that leaves "swirls". If you see "swirls" it has been decked. Straight lines are the "broach" marks.
Hope this helps.
Folks have gotten pretty good at recreating "broach marks" too these days. Just ask the good folks up at Engines Limited (sorry to freak out those of you who have engaged them for their broaching-restamping services). Folks have certainly gone beyond the "grind off the old pad with a rotary grinder days".
Sounds like this ebay seller is indicating that the pad has been correctly recreated - either on the original engine that "had to be decked" (the likely story you will hear) or using a cast-date-correct replacement engine.
j/k
