Dash Pad Installation
I recently purchased a 58 project. It came with a lot of loose parts so I have to figure out what they are and where they go. It should be fun.
Now I am working on installing the dash pad. Not only was it expensive, but I don't want to mess it up. I have only one shot to get it right.
Is there sequence to installing a dash pad? I'm attempting to install one on the 58 (everything has been removed from the car). I was told the dash pad needs to be installed first, then the windshield. But I noticed the bottom windshield frame end bolt/studs need to have the nuts installed when I install the windshield. With the pad installed, how can the nuts be installed without ripping back the new dash pad ends (by the grab bar) without wrecking it?
Thanks, Tom
Get the NCRS disc with all of the collective articles ever composed for tha C-1. It has all of the gory details you will need for the successful installation of a pad.
I have touched every nut bolt and washer on my '60 resto and the dash pad was by far the most frustrating part of the whole job.
Rule of thumb, if you think you have removed enough foam from the back of the pad to install your cluster or AL insert behind the grab bar you are probably wrong. Keep (cautiously) scraping.
Now that I have done the job twice I could do it in a quarter of the time which is frequently the case on all of these projects. Find someone who has actually installed one to help you.
Not someone who read about it, not someone who watched someone else do it, not someone who has dreamed about installing a pad but someone who has completed the job soup to nuts. ...and you may be nuts before it's over.
Keep dry fitting that baby and go slowly.
Best of luck to you.
Ralph
Ralph
