1962 Corvette heating problem
) how about the fan? are you using a clutch-type fan, or a solid hub fan? if it's a clutch type, maybe it's bad....Bill
You DO have all the fan shrouding in place, right?
Doug
but one of his pet peeves is making sure the distributor is correctly mapped, that the vacuum advance is correct, and more importantly functioning properly. I am not sure of the Echlin number for the can, someone will chime in and give it. Replace it, its cheap $$$$, and it is one of the main sources for overheating......
and you thought it was due only to the radiator and water pump......
1. Is the radiator lower fiberglass closure panel in place? This is the fiberglass panel that extends from the bottom of the radiator support to the front valance of the car. It is mounted with screws and sealed with sealant. It keeps air from coming in the grill and under the car.
2. Do you have the gaps around the front of the radiator closed with the factory-installed rubber strip panels?
3. Is your fan shroud complete all around? I found that sealing the gaps around the fan shround against the radiator helped. I used weatherstripping pieces originally intended to be used at the rear of the convertible top!
4. Initial ignition timing at 10 to 12 degrees? Vacuum advance on distributor? If so, is it an Echlin VC 1810 or GM equal?
5. Vacuum hoses for vacuum advance connected to full ported vacuum at the carb base?
6. Are you using a CLEAN (inside and out) radiator, preferably and aluminum replacement? Are your hoses new and does the lower one have a spring inside to prevent collapsing? Are your running a 180-degree thermostat? 50-50 mix of antifreeze and distilled water?
7. Is your carburetor calibrated properly so that it is not running lean?
8. If you have a fan clutch, is it operating properly? Should spin no more than 2 times when cold. Should be stiff to turn when the engine is hot and OFF. Is your fan the proper 5-blade fan, not an aftermarket fiberglass one that were so popular in the 60's? Assuming your fan is the proper one, are the blades approximately 50% in/out of the fan shroud?
I found that sealing around the radiator with sheet rubber strips and silicone sealant, using the convertible weatherstrip around the fan shroud openings and installing a 7-blade GM factory 17-inch fan with a Z-28 fan clutch I have plenty of cooling now on my 327-340HP, vacuum advance equipped 62.
Hope these tips help.
oWEN
Most of the replacement sending units make the gages read high. A resistor in series with the sending lead can correct the gage reading.
Most of the replacement sending units make the gages read high. A resistor in series with the sending lead can correct the gage reading.[/QUOTE
Hi, I agree a resistor can correct the gauge reading but it has been my experience with this fix that the reading will not be linear in function, in other words you can correct the guage to read properly over a certain narrow range but it will not be correct over the entire range. In my case I just experimented with resisters until the gauge was reading correct at 180 degree's. Just thought you might want to be aware of this.
Larry
Larry
I set mine so the gage looked right at normal operating temperature. Kawasaki had a problem with one of their sportbikes and provided a resistor to set the gage in a less "stressful" zone.
engine overheating has always been a mystery to me, probably something to do with gremlin's....
now that i'm installing a/c, things MAY change...
Bill
Doesn't help you but to let you know that you are not alone...
Scott
