63 split window coupe
Old Nov 2, 2006 | 07:11 PM
harry miller's Avatar
harry miller
Default 63 split window coupe
Does anyone know the proper location of the battery ground cable?
Old Nov 2, 2006 | 07:45 PM
63C2splitter's Avatar
63C2splitter
CF Senile Member
St. Jude Donor '08
Starter mounting bolt. Section 12, sheet A10.00 (page 188) of the AIM. Your page number may vary.
Dave
Old Nov 2, 2006 | 07:53 PM
ratmotortom's Avatar
ratmotortom
Platinum Supporting Dealership
My 63 340HP ground cable connects to the bellhousing bolt. Roughly at the center position bolt on the passenger's side. Splitter is correct though, the assembly manual shows it grounding to the starter bolt ! Might have to change mine. Never noticed this detail. learn something new every day !
Old Nov 2, 2006 | 08:43 PM
67L36Driver's Avatar
67L36Driver
How about a car with AC (no starter bolts on driver's side)?
Old Nov 2, 2006 | 08:49 PM
62Jeff's Avatar
62Jeff
I can't say for a 63, but on my 65 with AC the ground cable goes to the bell housing bolt just above the clutch fork.
Old Nov 2, 2006 | 08:50 PM
Trophy Blue's Avatar
Trophy Blue
If you have A/C, then it bolts to the driver's side bellhousing.
To 63 split window coupe
