help asap
Old Nov 8, 2006 | 02:18 PM
justatoy's Avatar
justatoy
Default help asap
can anyone help me here is my problem i have a 1965 vette putting a 1967 big block hood on the insert when you install doesnt sit flush it about a half inch away when it bottoms out is there a fill in spacer or it because its a after market hood please help its in the paint booth while i type i may have to fill in the drill holes please help thanks
Old Nov 8, 2006 | 03:01 PM
LB66383's Avatar
LB66383
My guess is that aftermarket hood isn't made to the exact same dimensions as the factory hood, so the insert doesn't fit right. There is no spacer.
Old Nov 8, 2006 | 03:50 PM
justatoy's Avatar
justatoy
ok found out you have to cut it out thanks
to make it fit
Old Nov 8, 2006 | 04:10 PM
JohnZ's Avatar
JohnZ
That's why it pays to trial-fit ALL trim/hardware parts before paint, so you don't have to cut/grind/drill anywhere after paint.
Old Nov 8, 2006 | 05:57 PM
justatoy's Avatar
justatoy
RT YOU ARE I DIDCHECK BEFORE I PAINTED THOUGHT I HAD A WRONG INSERT ALL FIXED NOW
To help asap
