What would it take?
TIA
Danno
Clutch pedal removed your looking at a little more time and and a little more $$$$, but no big deal.
Pretty easy swap. The powerslide stuff should be worth some money as well to offset the price of the new stuff.
I would look into one of the 5 speed conversions myself if I was gonna do it. There are a few vendors the sell everything you need soup to nuts for the conversion.
you'll need the following parts..
clutch pedal and all linkage including, bell crank, ball stud,linkage rods and springs... bell housing, clutch, pressure plate, and flywheel, clutch fork, and throwout bearing, gearbox, shifter, (possible driveshaft and slip yoke) if the PG is shorter or longer than the OE gearbox, and if the spline count is different.
you can probably get most of this in a kit from somewhere, as I think all the pieces are available in the aftermarket or as reproductions.
aside from gathering all the parts, its not a hard swap at all.
Aaron
