Corvette Script Valve Covers With PCV?
Old Nov 17, 2006 | 01:07 AM
bweaver999's Avatar
bweaver999
Originally Posted by CoupeKeeper
After reading all the good info, I am not sure if my current set up is correct. I've got a 64 327 with an Elderbrock Torker intake. I am using carb base for PCV to one valve cover and air cleaner base to the other cover, same size hole as the PCV valve. Before I explore too far for the holes in the covers vs. drilling intake, is my current set up adaquate?
Sounds like the way later model cars were configured. They had the oil filler and PCV hole on top of cover on one side, emblem and PCV on the other. Later model covers on ebay are in the same price range.
YourCover.con Corvette:
http://www.yourcovers.com/vc_11026.shtml
Chev, area for PCV. Vette cover sounds like it has the same area for PCV:
http://www.yourcovers.com/valve_cove..._pol_lg2_2.jpg
Old Nov 17, 2006 | 07:01 AM
Qblue92's Avatar
Qblue92
St. Jude Donor '08
I put a hole in mine on the left rear cover. Its not very noticable. Someone else told me you could use an oil fill tube from a SB midyear that has the vent tube on it. That might help.
Old Nov 17, 2006 | 07:37 AM
tentuna's Avatar
tentuna
Anyone modified corvette script valve covers for PCV? Pictures would be great
Why not use a 66 oil fill tube with a threaded fitting for a PCV valve, nothing to modify and easy to reverse
