I have seen some places offer tp powdercoat engines rather than paint them.. how exactly do they do this?? I thought 500 degrees the the point at which this stuff melts and adheres to the metel?
I'm not sure if you are worried about the heat of powdercoating damaging your block, or that the powdercoating will melt once your engine is running. Neither will occur.
Most powdercoating is done at between 350 and 400 degrees F for 15 to 20 minutes. This temperature will not harm your block. Most machine shops now use thermal cleaning ovens instead of ' hot tanks ' to clean parts. These ovens bake parts at over 700 degrees F.
The block and heads will never see much more temparature than the water in the block, except for the area where the exhaust manifolds are bolted on, but the gasket acts as an insulator.
I powdercoated mine myself. Many people powder coat the block and heads prior to machining, I chose to do it after partial assembly. I used an infrared lamp to heat the surfaces to cure temperature (target of 375 for 15 minutes for the powder I used). Using an infrared thermometer, I monitored the temperature of the surface beneth the lamp and cured an area at a time. Moving the lamp as the current area finished curing. It is a slow tedious process, but I was able to direct the heat and precisely control it. In the picture below, the valve springs never got above 200 degrees. I used sacrificial spark plugs, head gaskets, and timing cover. I used asbestos tape to mask other areas where I didn't want powder to go. The sheet metal parts were done separately in an oven where the temperature could be controlled more precisely. Intake, carb, water pump, fan, starter, just about everything was powdercoated.
Wow that looks great... I was mostly concerned abouthte area close to the exhaust ports.. where exhaust manifolds/headers will go. My last engine had consistant EGTs of 1450 degrees and didn't know how much of that would transfer to the surface of the powder coated areas.
I used an IR gun to measure my exh. manifold temp a few weeks ago and got 420ish. I asked around and was told that regular PC wouldn't survive on the exhaust like that. The rest of your block should be ok. Suppliers make a PC that's supposta be good for 1000 degrees.
I started a side business doing it and its been cool so far.
This engine hasn't been started yet, but I also did my Jeep engine the same way but in Gold. The header was stainless steel so I left it alone, but the mating surfaces were powdercoated and show no signs of heat discoloring.
The exhaust manifolds on the Vett engine were done with a special high temp cast iron color that is supposed to be good to 1200 degrees. I don't plan on pushing this car hard for very long durations so I am confident that it will hold up. If i were racing it, I'd be a little concerned.
I'm a little surprised at your EGTs of 1450. When we raced the 240Z, 1275 was the magic limit. Anything above that and we started having troubles.
I was told by the guy running the dyno that 1500 was max..lower the better.. We did a number of runs and a couple temps measured that high worse case. Was your 240z gas I assume? Not alchy?
