63 Split window Fuelie engine ID
Mike
oWEN
You should get the car evaluated by a '63 expert before spending $65,000. There are a lot of things beyond the block that might affect the market value of the car.
It would seem impossible for anyone on this Forum to be able to help you since the answers are already known. Good luck.
If the seller is saying it is all original and numbers matching, you already know the motor is not and the FI is not, so that brings into question the rest of the car (if the seller is misrepresenting anything). Those 2 items alone are very expensive as are many other 63 items.
Don
Does anyone know of an expert in the Philadelphia area I could hire to judge the car? Thnaks again and have a great Thanksgiving
The F1568? Not right either. Should be a 4 digit number only.
These #'s are on the tag riveted to the side of the FI doghouse. Chuck
Thanks Chuck I'll take another look now that I know what to look for.You guys are great. Sorry I'm such a novist....Bill
Its been heavly restored to nice driver condition with a '67 front and stinger hood, color change, interior color change, fender flairs, aftermarket ac, even the gas cap lid is incorrect.
Are there any other ways to know for sure?
oWEN
M.
Thank you for the kind words Venari.
Cheers
oWEN
Also, check where the FI Emblems are located on the side of the front fenders. Many that have been dummied up are not drilled in the exact/correct locations. The "J" in injection should be almost directly below the bottom point of the crossflags. From the inside of the engine compartment the 3 holes for the FI emblem should come through almost right near the top of the bonding strip.
Other things to note in addition to those mentioned:
There should be no steering damper
Should have a 6qt oil pan
80lb oil pressure gauge
Tach 6500 redline (mentioned)
Did you check the Trim tag to see if it is the correct color?
Heads: 3782461 and dated before build date of car
Exhaust manifolds L/3797942 R/3797902
Fuel Injection Unit: 7017375 - #3xxx
Intake: 3826810
Thermostat Housing: 3827370
Distributor: 1111022 - Dated
Coil 1115087
Alternator: 1100628 and dated
Starter: 1107242
Fuel Pump: 4657
Fuel Filter: GF90
Waterpump - 3782609
Radiator: 3155316 and dated
Expansion Tank: 3155416 and dated
Radiator Support: The real deal - 63 only. Not a service replacement or 64/65?
Rear Differential: Dateed and should be 3.36 or higher posi
Bellhousing: 3788421
Transmission/Muncie: 3831704 / Vin should match
Shifter - original muncie?
Steering Box - 5666723
Master Cylinder: 5462389 / dated
Horn Relay: 824-12
Voltage Regulator: 1119512 / Dated
All glass original and correct codes and dates?
Horns (Real almost impossible to find 63 - 9000455 & 9000456
Headlight Buckets should be Fiberglass
Glove Box - One year only
Valve Covers should not have casting flaw in the "O"
Parking brake is 63 only setup
78 vette-sa. "Parking brake is 63 only setup" What's the difference? Thanks
You wouldn't happen to be from Yonkers originally would you?
Not from Yonkers but close.
The 63 PB front cable attaches to a swing-arm mounted on the chassis directly below the driver. ONe cable then crosses over the tonque on the differential (also unique with a bolt holt for the cable clamp).
