Window date codes
Old Nov 26, 2006 | 10:55 PM
Greg Bull's Avatar
Greg Bull
Navigator
Default Window date codes
I have a '67 coupe and was wondering if anyone knows if there are visible date codes that would designate the glass is original.
Thanks,
Greg
Old Nov 26, 2006 | 11:14 PM
Stingray1967's Avatar
Stingray1967
Yes, there are codes. Look for two letters. The first letter will tell you the month and the second will tell you the year. Unfortunately, it is coded somewhat.
For example, the driver's window on our 67 shows GA, which is April 1966.
I would expect on your car, the second letter to be either an "A" for 1966 or a "Z" for 1967.
Post the letters once you find them.
Also, here is an interesting article.
http://www.valvoline.com/carcare/art...cid=5&scccid=8
Old Nov 26, 2006 | 11:18 PM
Procrastination Racing's Avatar
There are date codes, but they won't mean the glass is original, just the correct (or not correct) dates. If you have not owned it long, then a previous owner/restorer could have installed correctly dated glass.
There is a two letter code. There is also a two letter and number code, like AS-1, AS2, that is not the date code. This is the American Standard specifications for the type of glass.
If you get the date codes for each piece, you can look them up in the NCRS 1953-1967 Corvette Specifications Guide or someone here can do that for you.
Old Nov 28, 2006 | 11:37 PM
Greg Bull's Avatar
Greg Bull
Navigator
Thanks for the info and the article. Very helpful.
Greg
To Window date codes
