I'm looking at 2 Rally Red '65 327-365hp convertibles and I'm having some problem with the trim tags. With both cars so similar, I would think the tags should be very similar but they aren't - is one (or both?) of them not correct?
I bought the books "Corvette Buyer's Guide 1953-1967" and the "Standard Catalog of Corvette 1953-2005" but they haven't been too much help with this. If someone could help with these and recommend a good book for me to get, I would appreciate it.
This first one bothers me most. Under style it says 19 437. I thought the first number should be year (65), and convertible should be 467. This looks like the trim tag of a coupe to me and I don't understand why the year isn't included. The UU (red) and 402 (black leather) seem to be ok. And does A-7181 mean it is an AO Smith body?
This second one looks better I guess. The 65 467 is what I was expecting. The body S5057 is a St Louis body right? I'm confused why the paint says 900UU instead of just UU. I can't fully make out the trim, but the interior is supposedly a red/white combo - does it seem right?
That one tag is from a coupe and it sure looks poor. St. Louis cars had the 900 before the letters. Yes it it was possible to have a red and white interior.
Thanks, that's what I thought. I emailed the guy with the first trim tag and suggested that he had "accidentally" posted the wrong picture and requested a new picture - one with the VIN tag in the same frame since that picture checked out. We'll see what he says
Do you know a good reference where I can find this sort of information - like the fact that St Louis puts the 900 before the color code?
So the person quickly responded with a new picture of the trim tag and the VIN tag. VIN tag shows 467 (convertible), trim tag is still the same 437.
I guess someone retagged it at some point, probably to match a new paint job? Interesting that they didn't know enough to put a convertible trim tag on it.
Thanks for the help!
aside from the vert - coupe issue (which appears serious here), the style codes on 65s could vary in format . . . . .
The second example looks legit - 443BA is a red/white vinyl 2-tone interior for a car without Powerglide or power windows; I can't read the body build date code, but the car was built on December 28th, so it should be E27 or E28.
'65 St. Louis cars all had the "900" prefix on the paint code.
A.O. Smith trim tags didn't show the model year until 1966.
The single best reference for trim tags is the NCRS Authentication Library, Volume One - the "Trim Tag Book"; available from the on-line store at www.ncrs.org. Nothing else comes close.
I would question both of those trim tags. The first one for the obvious reason already stated, the second one for both the build date and body number.
On the second car the build date appears to be L20 which is too late for that VIN number (5323).
I don't know for certain but I also suspect that the body number (5057) is too late for that VIN number. I have a St. Louis built '65 coupe with a much earlier body number and a much later VIN number, so, assuming the ratio of coupes to convertibles stayed the same throughout the year then it should follow that the trim tag on the second car originally came off of a car that was built much later in the production run.
Thanks!
Hello,
Lets get all the numbers you have about the 2 Corvettes.
Example #1
What it the VIN ?
Build date L 07
Style 19 437
Body A-7181
Trim 402
Paint UU
Example #2
The VIN : 194675S105323
Build date I 20
Style 65 467
Body S5057
Trim 443 BA
Paint 900 UU
Can you confirm all the information stated above? (Add and correct)
Then we all can see the facts.
Thanks,
Drew Papsun
Vipermike - wow, I was kind of assuming the 2nd one was aok, but I see your point. VIN 05323 should have been produced in Dec '64, but L20 (if it is L20 - it's a little blurry) is not until July '65 right? And even if we are reading that date wrong, body S5057 certainly seems much later than VIN 05323.
Also, notice the apparent wrinkles on the trim tag just above the rivets, as if it had been pulled off.
Also, please look closer at the rivets. The set of rivets on the trim tag have centers, while the rivets on the VIN tag are hollow. Which are correct? Looking at some other pictures I have handy, it looks like the VIN rivets are not correct? Why would someone retag the VIN?
Wow, this is really freaking me out, these are just the first two trim tags that I've looked at and they are both bogus? How rampant is this stuff?
Drew - I think you are right, example 2 is an I20, not L20 but the discrepancy remains. Here we go:
Example #1
The VIN : 194675S122422
Build date L 07
Style 19 437
Body A-7181
Trim 402
Paint UU
Here is the follow-up picture I was provided for example 1:
The trim tag date (L07) and the VIN birthday both would seem to be July '05, but the coupe code is so flagrant, and the metals of the two tags are very different. Although he quickly responded when I wanted more pictures, he hasn't responded since I pointed out the problem...
Example #2
Build date I 20
Style 65 467
Body S5057
Trim 443 BA
Paint 900 UU
Again, the VIN number suggests Dec '64 but the trim tag says April '65.
I was doing this as a learning exercise, I think I'm learning more than I intended
I'm not sure that any conclusion can be draw by the centers (or lack there of) in the rivets.
VIN tags prior to approximately number 9000 in '65 used round stainless steel rivets for attachment. Later VIN tags were attached with rosette rivets. The VIN tag rivets seem to be round (as they should be) but look different than the rivets attaching my VIN tag (my tag also has round rivets); however, the photo provided is not clear enough to tell for certain.
Weighing the evidence of the mismatched build dates and what appears to be incorrect rivets on the VIN I would want much more information about that car before making an offer or buying it. I would inspect the VIN tag, trim tag, and attaching rivets very closely; check the VIN number on the engine to see if it has been restamped; check to see if the VIN stamped on the frame and transmission matches the VIN tag; and finally check casting dates on every part on the car to see if I could come up with and educated guess as to when the car was actually produced.
In my opinion the first example is not a GM produced trim tag. The basic plate is wrong. The placement of "Detroit Michigan" on the second line is not even close to an original trim tag when compared to where it should line up with the top line.
Page Campbell
I passed on both of these cars (wasn't very far into the process with either). The seller of the second one (the one where the VIN is Dec '64 and the trim tag is Apr '65) followed up with me to see if I was still interested and I mentioned the discrepancy. He replied today and said NCRS allows a 6 month gap. I know that is true for certain parts, but is that true for the trim tag?
Also, it seems that it is backwards, that the trim tag would have to be less than 6 months older, not newer, than the VIN. It doesn't make sense to me that NCRS would allow a trim tag that shows the body was made months after the vehicle came off the line. I'm being fed a line of aren't I?
Further, in my interpretation, NCRS allows parts that date match within 6 months, but isn't changing the trim tag in order to change the color (which is what I assume happened) counterfeiting under NCRS rules and the car would be disqualified?
Is there any correct reason to put a different trim tag on a Vette that NCRS does allow?
The "six-month rule" only applies to dated parts vs. the car's final assembly date; no such discrepancy is allowed between the VIN and the body build date on the trim tag. No such thing as a December '64 VIN on a car with an April '65 body build date - tags have been swapped or faked. On a St. Louis-bodied car, the body build date will always be within two days of the date the car came off the line - usually one, sometimes the same day. The guy is feeding you a line of BS . This discrepancy would be spotted instantly on the judging field, and would automatically limit the maximum award the car could receive to a Second Flight, regardless of how well the car actually judged; it would also be scored automatically as an interior and exterior color change, losing all points, and the owner would usually be advised that it would be in his best interest to withdraw the car from judging.
Yeah, JohnZ, I am definitely not interested in this car. I'm just trying to figure out if I should bother pointing out the problem further with this seller (an oft-discussed dealer) or just not bother.
I'm quite certain that they know these cars inside and out and they know this stuff a lot more than I do. So I figure they already know about the problem and it bothers me that they are glossing over the issue with misinformation with potential buyers rather than being upfront.
I've tried to be careful not to be specific about the car or seller, but I wonder if it would be appropriate to disclose this car to the forum in case anyone else is looking at it.
I would put this issue to rest right now and not worry about it anymore. You don't want to get enemies (if you will) on this forum or in general. Although it would help potential buyers to point out the issue on this public forum, I'm just not sure its a good idea.
