less then zero, deck height.
PART #.......... BORE.....THICKNESS........CC's
FEL-PRO
Small-Block
1003.............. 4.166........... 0.041........ 9.1
1004.............. 4.190........... 0.041.........9.2
1010...............4.166........... 0.039........ 8.9
1014.............. 4.200............0.039........ 9.0
1034.............. 4,200........... 0.041........ 9.3
1043............... 4.080.......... 0.039......... 8.2
1044............... 4.200...........0.051.........11.2
1094............... 4.100...........0.015..........3.2
Big-Block
1012................4.640...........0.03 9.........10.0
1017-1.............4.540...........0.041..... ....10.9
1027............... 4.370...........0.039.......... 9.7
1037............... 4.370...........0.039...........9.7
1047................4.540...........0.03 9..........10.5
1057............... 4.630...........0.041..........11.3
1067................4.630...........0.03 9..........11.0
VICTOR REINZ
Small-Block
3514SG......... 3.840............0.045..........8.4
5746.............. 4.100............0.026..........5.4
+1178SSB..... 4.100........... 0.020..........4.1
+1178SG....... 4.160............0.045..........9.8
3432SG..........4.190............0.045.. ........10.0
1178SCR........4.190............0.044... .......9.8
3512.............. 4.190............0.040..........8.8
Big-Block
3884SG......... 4.520........... 0.045..........11.5
5950SC..........4.370............0.042.. ........10.0
5946SC......... 4.630............0.042..........11.2
4886.............. 4.578............0.042..........11.0
4918...............4.578........... 0.042..........11.0
5951 SC........ 4.370............0.042..........10.6
McCORD
Small-Block
94-2010.......... 4.140............0.042..........9.3
94-2011.......... 3.840............0.042..........8.0
94-2017.......... 4.190............0.042..........9.5
Big-Block
94-2013...........4.370............0.042... ......10.3
ROL
Small-Block
HG31010HT...3.825............0.051...... .....9.6
HG31600........4.090........... 0.020.......... 5.4
HG31000HT... 4.175.......... 0.044.........11.4
HG31250HT....4.200 .......... 0.051.........11.6
Big-Block
HG31170HT... 4.345 ...........0.044..........12.4
MR. GASKET
Small-Block Solicor
5727................4.190........... 0.044..........9.8
5728................4.220........... 0.042......... 9.3
Big-Block Solicor
5730............... 4.370............0.042..........10.2
5731............... 4.630............0.042..........11.2
5732............... 4.370............0.042..........10.6
5733............... 4.540............0.042..........10.8
If you are drag racing, I agree with Mr Vizard, you can run a 25 to 28 thou squish with a well built engine. For fast street or endurance engines, 35 thou is more like it. Knockabout shade tree rebuilds, stick to 40+.
The tighter the squish, the better the engine will be for the quality of burn, knock resistance, volumetric efficiency and thus torque. My 327 is going to run as little as I can get away with above 30thou because my heads have quite large chambers for a 327 and I don't particular want to machine them to get the CR up. I think I'm fighting a losing battle there, but we'll see when I measure the heads.
Low squish was also a reason for me to stick with 23deg heads - I wanted to use a relatively plain-Jane piston with 23deg recesses already cut. I'm still going to have to clearance check each one, but since my short-block is being done by a race shop, I expect very tight grouping on the CHs in the bores.
I am so looking forward to being where you are now with your block. It looks soooo funky.
Mark.
(I love this hobby.)
