Hi, instead of rebuilding my matching 327 in my 65, Im buying an early 327 crate motor, I thought about using a better distruibutor. Is anyone using a distributor like this one from ecklers? or one similar? Why couldnt I use my ignition shielding as it states at the bottom of the decription?
Ummmmmmmmmmmmm, maybe because the HEI is waaaaaaaaaaay to big to fit under the top shield?
I might make a comment here. Why not keep your original dist and simply install one of the aftermarket electronic conversion units, such as PerTronix, etc.
You can inastall a Pertronix unit in the same amount of time it takes to install new points, condenser and adjust the dwell.
There are now some electronic conversion units on the market which completely replace the points and condenser. These conversion units are TOTALLY contained inside the distributor cap, there are NO external boxes or modules. These conversion units ARE NOT super duper fire breathing ignitions that produce millions of volts. But, because of their design, especially when used with a HD coil, they do provide increased voltgage (just exactly how much more is debatable, but some). Also, the inherent design of an electronic triggering mechanism, rather than breaker points, possible problems such as point bounce at high rpm is eliminated. As a result, you have the benefits of electronic ignition, retain your original distributor and have a stock appearance with no visible add-on components.
Just something to keep in mind as a possible option.
If you go the install electronics route, you need to insure all the mechanical parts in your distributor are working correctly. I went with a Mallory Unilite distributor from Jegs: http://forums.corvetteforum.com/newr...1&p=1557954995
Total cost was under $500. Fits under the sheilding fine. It does not have a vacume advance but my car runs a lot better then with the original I replaced.
I currently have a complete Mallory Unilite distributor for sale on eBay. The auction ends Monday night.
I'm old school and havent worked on motors/ignition since high school, so dont laugh. If I use the mallory unilite will it fit under my 65 ignition shielding? It doesnt have a vacum advance, so will I need a carb with mechanical secondaries? (this is OK because I have a nice one). I just need to run power to it and get a good coil? Thanks for the help
Here is another option, the MSD pro billet tach drive, p/n 8572. Has vacuum advance as well. $340.00 from Summit Racing. The only downside is you have to run an ignition box with it, and they start at $170.00.
p.s. There is no correlation between vacuum advance and vacuum secondaries on the carb. Vacuum advance is for ignition timing, vacuum secondaries is the method of opening the the third and fourth barrels on the carb (as opposed to opening them mechanically).
Why would you want to spend $400.00 for a "better" distributor that isn't "better" at all? The one you have now will work just fine (assuming it's in decent condition), is easy to rebuild if it needs it, and can run either points or a drop-in electronic conversion.
Use your original distributor, rebuild it, re-bush if needed, dial in the vacuum can and it will work great. I've rebuilt all my stock point distributors it's the only way to go in my opinion. We're running an MSD in the 75 and it has been working fine but I would have left the GM HEI in that car. Spend your money on things you could use more.
Good luck
