GM 572- Do it Yourself Engine
Old Dec 12, 2006 | 09:41 PM
KyleDallas's Avatar
KyleDallas
Default GM 572- Do it Yourself Engine
Anyone thought of building a 572 by bypassing some of the General's
expensive parts.. substituted with your own?
GM Parts Direct list the complete carb to pan GM 572 Crate as:
GMPP #12498793... $12,421.97
Here are some parts/prices for a 572 assembly.. you fill in the blanks.
Part.................................... .....................................Pri ce.......
GM# 25534364 Tall Deck Sportsman Block .......................$1893.53
GM# 12499255 572/620 Head (2@889.22 each) ...............$1778.44
GM# 88961557 572/620 Cam ........................................ $229.83
Ohio Crankshaft 572 Rotating Assembly(Pistn,Rods,Crank).. $1899.00
SUBTOTAL of Block,Heads,Cam, and Internals....................$5800.80
572/620 GM $12,421.97
...........sub - $5,800.80
............... =$6,621.17
http://www.ohiocrank.com/rotating.html
http://www.gmpartsdirect.com/
Old Dec 12, 2006 | 10:05 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
And if you used some REAL heads..that sucker would make much better power!!!
JIM
Old Dec 12, 2006 | 10:25 PM
KyleDallas's Avatar
KyleDallas
I aggree Jim... I just thought I would toss these numbers and parts
out there for those who like going the Cubic Inch route...
I'd rather have some AFR's or Merlin 16 degree BBC heads than cubes.
Old Dec 13, 2006 | 04:48 AM
knight37128's Avatar
knight37128
Raised exhaust and a tall deck block.................. Try fitting that in a corvette.
Old Dec 13, 2006 | 06:52 AM
cbernhardt's Avatar
cbernhardt
C1 of Year Finalist (track prepared) 2019
I'm trying, I'm trying:
Old Dec 13, 2006 | 07:20 AM
KyleDallas's Avatar
KyleDallas
Check out the "King Ray"... ask John Z for details.. or perhaps he'll
weigh in on some of the particualars... it has been accomplished in a
midyear..
Old Dec 13, 2006 | 07:55 AM
knight37128
midyear..
Yes I know it can be done. Money was not a factor.
If you are going to put a tall deck in one; why just a 572?
Old Dec 13, 2006 | 07:57 AM
knight37128
Does look like a fun project.
Best of luck with it.
Old Dec 13, 2006 | 12:05 PM
JohnZ's Avatar
JohnZ
midyear..
Not a big deal - used a stock GM 3x2 setup with Moroso intake spacer plates, only had to remove 1/4" from the height of the foam support screen in the air cleaner.
Old Dec 13, 2006 | 12:20 PM
65nassau's Avatar
65nassau
It's interesting to note what appears to be a very small amount of surface area on that car, John. I'm sure the people who did it must know what they are doing but I'm wondering about how it was selected.
I have heard about people using the 383 and having a 3" high air cleaner elements with a drop base. It seemed like they were very concened about having lots of filter surface so as not to choke the engine.
I would guess that the type of filter media would come into play, but is there some sort a formula for area of air filter needed for 'cubic cinches' or 'air volume' ?
Old Dec 13, 2006 | 04:35 PM
oldschoolvette's Avatar
oldschoolvette
Interesting
Old Dec 13, 2006 | 05:01 PM
Last 62's Avatar
Last 62
ADD
Machine work
oil pump
pan
timimg set
timing cover
valve covers
head bolts
lifters
pushrods
etc.
etc.
etc
The gap closes.
Jim
Old Dec 13, 2006 | 05:14 PM
Viet Nam Vett's Avatar
Viet Nam Vett
2015 C2 of Year
St. Jude Donor '04-'05-'06-'07-'08-'09-'10, '14-'15
Not being and engineer.......I gotta say that it doesn't look like old King Ray is gonna breathe to well thru that little slit..Maybe a BB 427 but I'm not to sure about a 572.
Who wants to run those numbers..?? John Z ..???
Old Dec 13, 2006 | 05:18 PM
Viet Nam Vett
2015 C2 of Year
The gap closes.
Jim
........$12,421.97
Old Dec 13, 2006 | 05:59 PM
KyleDallas's Avatar
KyleDallas
ADD
Machine work
oil pump
pan
timimg set
timing cover
valve covers
head bolts
lifters
pushrods
etc.
etc.
etc
The gap closes.
Jim
This is what JC Whitney, a drill hone in your garage, and a
Clymer book are for. You didn't know??
Old Dec 13, 2006 | 06:02 PM
65 DENCO's Avatar
65 DENCO
NICE!!!
Old Dec 13, 2006 | 10:23 PM
knight37128
Not to pick a fight.............. Why no power steering? Could he not get it to work with the raised block?
A/C yes
Alternator yes
Power steering ? No...................
Old Dec 14, 2006 | 02:43 PM
JohnZ's Avatar
JohnZ
A/C yes
Alternator yes
Would have worked fine, just wasn't in the original "recipe" for the car. Had to change the oil pan anyway, as the 572 comes with a truck pan that won't clear the front crossmember (used a Milodon).
To GM 572- Do it Yourself Engine
